I have a doubt regarding the robot state publisher node. I am loading an urdf file validated with the check_urdf. When launching the robot state publisher, I obtain some suspicious values on the Average Delay field.
I am running under Electric version and the launch file I am using looks like the following:
<!-- robot urdf model -->
<param name="robot_description" command="cat $(find robot_base)/model/robot_base.urdf" />
<!-- robot state publisher node -->
<node pkg ="robot_state_publisher"
      type="state_publisher"
      name="robot_state_publisher">
</node>
The tf_monitor outputs this result:
RESULTS: for all Frames
Frames:
Frame: /front_laser published by /robot_state_publisher Average Delay: -0.499885 Max Delay: 0
Frame: /rear_laser published by /robot_state_publisher Average Delay: -0.499884 Max Delay: 0
Frame: /vertical_laser published by /robot_state_publisher Average Delay: -0.499883 Max Delay: 0
All Broadcasters:
Node: /robot_state_publisher 51.2438 Hz, Average Delay: -0.499884 Max Delay: 0
I am not sure if this negative Average Delay values are due to some error or not. When adding a new frame from the odometry node which links to the robot_state_publisher base_link, the Average Delay outputs a more coherent value like 9.61504e-05.
Is everything running as expected or I have some bug on my setup?
Originally posted by joan on ROS Answers with karma: 245 on 2011-09-30
See the tf FAQ for the answer to this. This is normal behavior for certain nodes that timestamp data in the future.
Originally posted by Eric Perko with karma: 8406 on 2011-09-30
