Hi there,
I was wondering if it's worth investing in a high end PC to run Turtlebot, rather than using the advised laptop.
- Would it really give a boost to run a big CPU (i.e. i72600) or is it throwing money out of the window ?
- Is it possible to use the graphics card processing capacity for some applications ?
- What is the RAM impact as well ?
- What is the data bitrate output of the Kinect ? edit: it's 13Mbps
I did not find much information on this topic, but if this type of question has already been answered I apologize in advance. Jonathan
Originally posted by Jonathan on ROS Answers with karma: 33 on 2011-09-21
Comment by Jonathan on 2011-09-22:
My bad, its Mbps. It's stated here : http://openkinect.org/wiki/FAQ#What_is_the_frame_size.2Fbitrate_of_the_rgb.2Fdepth.2FIR_stream_contained_in_the_isochronous_usb_tranfers_etc..3F.
Comment by mjcarroll on 2011-09-22:
Out of curiosity, where does the 13Gbps number come from? That's greater than the 480Mbps that USB allows for.
Comment by TillScout on 2011-09-22:
I am having similar thoughts. I would especially like to know, what graphics power the Turtlebot needs. Since the visualization is done on a workstation I would expect the Turtlebot itself not to be very hungry here. Or does the Kinect data processing need much GPU power?
Comment by Jonathan on 2011-09-21:
Just found the answer to my last question it's around 13Gbps
Comment by patrick_hammer on 2012-02-16:
Did you ever build a souped-up turtlebot? I just installed a Mini-ITX mobo, low power i5 processor, and ssd in the cargo bay. Maybe I'll post some benchmarks
Comment by TillScout on 2012-04-11:
@patrick_hammer How does your solution work? How do you power the mini ITX board? Maybe you can post some more details on your project.
