Dear all,
http://robotics.usc.edu/ros/category/stacks/p2os says that a working drivable urdf model of the Pioneer2dx for gazebo/rviz is released.
How can I teleoperate a pioneer robot in a Gazebo simulation? I could visualize the pioneer robot both in gazebo and in rviz using,
roslaunch p2os_urdf pioneer3dx_urdf.launch
roslaunch p2os_urdf pioneer3dx.gazebo.launch
What should I do next?
By the way, after launching from above launch files, after few minutes, the robot automatically starts moving. Why is that?
Thank you in advance
CS
Originally posted by ChickenSoup on ROS Answers with karma: 387 on 2011-09-19
Comment by Arkapravo on 2011-09-24:
@Peshala : After those 2 commands, my robot did not move at all ! ......
You could try the pr2_teleop package, or the erratic_teleop package. Both of these allow you to issue cmd_vel messages via the keyboard. The erratic_teleop node provides linear x and angular z commands, which are all that you need for the Pioneer.
Originally posted by DimitriProsser with karma: 11163 on 2011-09-20
Comment by DimitriProsser on 2011-09-28:
Unfortunately, I could not recreate that error for you. Try using "rostopic echo /cmd_vel" and see if anything appears. Maybe you could also use rxgraph to check if anything is publishing to the wrong topics.
Comment by ChickenSoup on 2011-09-27:
Thank you for your reply. However, as I mentioned, the robot starts moving automatically and it cant be controlled from key board.
