How do I submit an attached patch to use the face_detector package in electric environment? I couldn't find ticket form in https://code.ros.org/trac/wg-ros-pkg
Index: test/face_detector_false_rtest.xml
--- test/face_detector_false_rtest.xml  (revision 53029)
+++ test/face_detector_false_rtest.xml  (working copy)
@@ -1,6 +1,6 @@
Index: test/face_detector_true_rtest.xml
--- test/face_detector_true_rtest.xml   (revision 53029)
+++ test/face_detector_true_rtest.xml   (working copy)
@@ -1,6 +1,6 @@
Index: manifest.xml
--- manifest.xml    (revision 53029)
+++ manifest.xml    (working copy)
@@ -16,7 +16,6 @@
Originally posted by Kei Okada on ROS Answers with karma: 1186 on 2011-09-19
The new ticket button appears once you login.
Originally posted by David Lu with karma: 10932 on 2011-10-18
