Does rosserial support ROS_INFO?
I tried using it, but the compile failed. I can see why this might be, as there is no "console" for output.
If so, is there a library or something to add?
If not, is there a way to send out a message other than standard publish?
Originally posted by dan on ROS Answers with karma: 875 on 2011-09-15
It can do ROS_INFO, but not with the same kind of syntax.
See http://www.ros.org/wiki/rosserial/Overview/Logging
You also need to be using rosserial from source in order to use this.
Originally posted by adasta with karma: 508 on 2011-09-15
Comment by dan on 2011-09-16:
oops, missed that doc. Thanks for the help.
