I'm having problems getting my model to work in gazebo: when I spawn my model in gazebo, I get a segfault. I'm almost sure it's due to my custom transmissions, because the model is working when the standard pr2 simple_transmission are used.
The backtrace is available here.
My model contains custom transmissions (which are almost copies of the simple_transmission.cpp, as you can see here.
I uploaded the generated model here.
Those transmissions are working on the real robot, but not in Gazebo.
Any ideas?
Originally posted by Ugo on ROS Answers with karma: 1620 on 2011-09-15
Comment by Ugo on 2011-10-24:
The root of the problem is that the pr2_gazebo_plugins/src/gazebo_ros_controller_manager.cpp instantiates a ''''pr2_hardware_interface::Actuator" object (line 470), and not my custom actuator (which inherits from the pr2 Actuator class). Is it not possible to have a custom actuator?
Comment by Ugo on 2011-09-15:
If I comment out the call to publishMechanismStatistics() in the ControllerManager::update() function then the simulation seems to be working fine.
It appears the problem is coming from the iteration on the actuator map in ControllerManager::publishMechanismStatistics(): the for (ActuatorMap::const_iterator it = model_.hw_->actuators_.begin(); it != model_.hw_->actuators_.end(); ++i, ++it) returns a segfault on the 3rd element.
Ok, I solved it by creating my own implementation of the pr2_gazebo_plugins/src/gazebo_ros_controller_manager.cpp.
This is available in the sr_gazebo_plugins package.
Originally posted by Ugo with karma: 1620 on 2011-10-25
