I am installing rosserial to use with an arduino and in the setup page, it has the cryptic lines: "If you installed rosserial from debs, all you have to do is copy the rosserial_arduino/libraries directory into your Arduino sketchbook. After restarting your IDE, you should see ros_lib listed under examples."
How do you get the rosserial debs?
It goes on to say how to install from source, but I'd prefer to use debs if I can find them.
Originally posted by dan on ROS Answers with karma: 875 on 2011-09-14
If you have already setup your ROS system following these instructions, you just have to:
sudo apt-get install ros-electric-rosserial
Originally posted by fergs with karma: 13902 on 2011-09-15
Comment by dan on 2011-09-15:
Thanks! Is that documented somewhere? I added it to the wiki page.
