Hi,
The suggested gyro for turtlebot is no longer available at Sparkfun.com. Does someone knows which other gyro can be used?
Thanks in advance,
Lucas
Originally posted by lucascoelho on ROS Answers with karma: 497 on 2011-09-09
if you're looking for a breakout board that will also work you can use http://www.sparkfun.com/products/8372 , it's not a drop in replacement but if you're looking for a breakout board this will work
Originally posted by mmwise with karma: 8372 on 2011-09-10
Comment by mmwise on 2011-09-18:
all you need is a 5V gyro.. it doesn't really matter how many axis and it should be somewhere between 150-300deg/sec
Comment by Marco on 2011-09-15:
For those willing to pay a high price for the adxrs613 breakout box there are still a few in stock at http://www.active-robots.com/sensors/gyros/gyro-breakout-board-adxrs613.html
Comment by lucascoelho on 2011-09-15:
I think that $ 60 is very expensive for a single axis gyro breakout board... Is possible to use a dual or triple axis gyro? Because Sparkfun has other cheaper options: http://www.sparkfun.com/products/10100
Comment by mmwise on 2011-09-15:
either will work, with the 300deg/s gyro you will need to claibrate you TurtleBot the default values will not be close enough. the board you suggest above would be a better choice because the default calibration values will be close and you might not need to calibrate.
Comment by Marco on 2011-09-14:
Would the e2 version of above, http://www.active-robots.com/sensors/gyros/gyro-breakout-board-mlx90609-e2.html , be an even better alternative, as it is also 150/s and has imilar sensitivity to the adxrs613?
Comment by Marco on 2011-09-13:
Besides the sensitivity being twice as low and the max speed twice as high, it seems similar to ad adxrs613. What kind of changes (software/hardware) are needed in order for this gyro to function correctly in the turtlebot package?
We haven't been able to find a drop-in replacement for that breakout. Our latest run of boards use an ADXRS652BBGZ. Unfortunately, this is a BGA package, requiring you to use a hot-plate to solder this chip to the board before adding other parts. It also has a different scale (250 deg/s instead of 150 deg/s).
There are also a few other support components (caps and a resistor) that are required. We're getting those fixes into the latest parts package soon.
At the moment, we haven't found anything which is pin-compatible and easy to hand solder.
Originally posted by Ryan with karma: 3248 on 2011-09-09
