The problem appears with:
  • zero gravity worlds (<gravity>0 0 0</gravity>) OR models with gravity disabled (<enableGravity>false</enableGravity>)
  • AND models that use <attach> and <include> to include additional models (for example a pioneer2dx with attached sonyvid30)
What to do to make it happen: teleport your robot into some location above the ground, for example run
rosservice call /gazebo/set_model_state '{model_state: { model_name: pioneer2dx_model1, pose: { position: { x: 0, y: 0, z: .6 }, orientation: {x: 0, y: 0, z: 0, w: 0 } }, twist: { linear: {x: 0 , y: 0 ,z: 0 } , angular: { x: 0 , y: 0 , z: 0 } } }}'
What I would expect to happen: The robot appears in the specified location, peacefully floating there.
What actually happens: The robot does indeed appear in the specified location. But it is usually rotating wildly, sometimes also drifting away from its position
A good example is the pioneer2dx_camera.world which I think lives somewhere in most Gazebo installations. Just change the <gravity> specification to zero and try the rosservice call above.
The question is now: Is this a bug? Are there other workarounds known than to not use <attach> and <include> on models?
Edit: I actually use the Diamondback Ubuntu packages. So maybe this isn't relevant for newer versions.
An example, from the pioneer2dx_camera.world file, which shows the behavior :
<model:physical name="pioneer2dx_model1">
  <xyz>0 0 0.145</xyz>
  <rpy>0.0 0.0 0.0</rpy>
  <model:physical name="sonyvid30_model">
    <xyz>0.15 0 0.09</xyz>
    <attach>
      <parentBody>chassis_body</parentBody>
      <myBody>sonyvid30_body</myBody>
    </attach>
    <include embedded="true">
      <xi:include href="../models/sonyvid30.model" />
    </include>
  </model:physical>
    <xi:include href="../models/pioneer2dx.model" />
  </include>
</model:physical>
An example which does not show the behavior :
  <xyz>1 1 0.145</xyz>
  </include>
</model:physical>
Any other models, that do not use the <attach>...</attach> + <include>...</include> tags are not affected, though I did not test all too many models. This is probably what you meant by "links".
Actually, when watching the "teleport operation" from a distance I can see what probably causes the spinning: The main body, for example the pioneer2dx_model1, appears at the new position instantly, but the attached body, for example the sonyvid30_model seems to remain at the old position for a very short time and then follows main body like it was attached with a rubber band or something the like. The ensuing impact then makes the robot spin and/or drift.
Originally posted by nitschej on ROS Answers with karma: 35 on 2011-09-06
Comment by nitschej on 2011-09-07:
No, visually it looks ok when paused. Parent and child model appear at the right spot instantly. But when unpausing again the behavior is all the same.
Comment by hsu on 2011-09-07:
based on your latest observation, this is because set pose did not follow nested models. It's sounding very much like a bug for nested models. If the simulation was paused, can you check if the "set_model_state" service call only moves the parent-most model?
Comment by Dimitar Simeonov on 2011-09-07:
Can you explain whether your robot has any links attached to it ? Does the behavior occur if you try to teleport different objects than the robot?
Trying with the pioneer2dx_camera.world confirms that there is a bug with setting pose of nested models in diamondback and electric. The problem is due to a bug in the recursive updates in Entity.cc. Ticketed.
Current work around is to combine nested models into a single model. For example, pioneer2dx_camera.world becomes:
<?xml version="1.0"?>
<gazebo:world
  xmlns:xi="http://www.w3.org/2001/XInclude"
  xmlns:gazebo="http://playerstage.sourceforge.net/gazebo/xmlschema/#gz"
  xmlns:model="http://playerstage.sourceforge.net/gazebo/xmlschema/#model"
  xmlns:sensor="http://playerstage.sourceforge.net/gazebo/xmlschema/#sensor"
  xmlns:window="http://playerstage.sourceforge.net/gazebo/xmlschema/#window"
  xmlns:param="http://playerstage.sourceforge.net/gazebo/xmlschema/#param"
  xmlns:body="http://playerstage.sourceforge.net/gazebo/xmlschema/#body"
  xmlns:geom="http://playerstage.sourceforge.net/gazebo/xmlschema/#geom"
  xmlns:joint="http://playerstage.sourceforge.net/gazebo/xmlschema/#joint"
  xmlns:interface="http://playerstage.sourceforge.net/gazebo/xmlschema/#interface"
  xmlns:ui="http://playerstage.sourceforge.net/gazebo/xmlschema/#ui"
  xmlns:rendering="http://playerstage.sourceforge.net/gazebo/xmlschema/#rendering"
  xmlns:controller="http://playerstage.sourceforge.net/gazebo/xmlschema/#controller"
  xmlns:physics="http://playerstage.sourceforge.net/gazebo/xmlschema/#physics" >
  <verbosity>5</verbosity>
  <physics:ode>
    <stepTime>0.001</stepTime>
    <cfm>0.0000000001</cfm>
    <erp>0.2</erp>
    <stepType>quick</stepType>
    <stepIters>100</stepIters>
    <stepW>1.3</stepW>
    <contactMaxCorrectingVel>100.0</contactMaxCorrectingVel>
    <contactSurfaceLayer>0.00</contactSurfaceLayer>
  </physics:ode>
  <rendering:gui>
    <type>fltk</type>
    <size>800 600</size>
    <updateRate>20</updateRate>
    <pos>0 0</pos>
    <frames>
      <row height="100%">
        <camera width="100%">
          <xyz>0.35 -0.5 0.43</xyz>
          <rpy>0 14 111.5</rpy>
        </camera>
      </row>
    </frames>
  </rendering:gui>
  <rendering:ogre>
    <ambient>0.5 0.5 0.5 1.0</ambient>
  </rendering:ogre>
   <!-- Ground Plane -->
  <model:physical name="plane1_model">
    <xyz>0 0 0</xyz>
    <rpy>0 0 0</rpy>
    <static>true</static>
    <body:plane name="plane1_body">
      <geom:plane name="plane1_geom">
        <normal>0 0 1</normal>
        <size>2000 2000</size>
        <segments>10 10</segments>
        <uvTile>100 100</uvTile>
        <material>Gazebo/Grey</material>
      </geom:plane>
    </body:plane>
  </model:physical>
  <model:physical name="cylinder1_model">
    <xyz>1 -1.5 0.5</xyz>
    <body:cylinder name="cylinder1_body">
      <massMatrix>true</massMatrix>
      <mass>1.0</mass>
      <ixx>0.01</ixx>
      <ixy>0.00</ixy>
      <ixz>0.00</ixz>
      <iyy>0.01</iyy>
      <iyz>0.00</iyz>
      <izz>0.01</izz>
      <cx>0.0</cx>
      <cy>0.0</cy>
      <cz>0.0</cz>
      <geom:cylinder name="cylinder1_geom">
        <size>0.5 1</size>
        <visual>
          <mesh>unit_cylinder</mesh>
          <material>Gazebo/RustyBarrel</material>
        </visual>
      </geom:cylinder>
    </body:cylinder>
  </model:physical>
    <xyz>0 0 0.148</xyz>
  <body:box name="sonyvid30_body">
    <xyz>0.15 0.0 0.09</xyz>
    <mass>0.1</mass>
    <ixx>0.01</ixx>
    <ixy>0.00</ixy>
    <ixz>0.00</ixz>
    <iyy>0.01</iyy>
    <iyz>0.00</iyz>
    <izz>0.01</izz>
    <cx>0.0</cx>
    <cy>0.0</cy>
    <cz>0.0</cz>
    <geom:box name="camera_bottom_geom">
      <xyz>0.0 0.0 0.02</xyz>
      <rpy>0 0 90</rpy>
      <size>0.15 0.14 0.04</size>
      <visual>
        <rpy>0 0 -90</rpy>
        <mesh>sonyvid30/sonyvid30_bottom.mesh</mesh>
      </visual>
    </geom:box>
  </body:box>
  <body:box name="sonyvid30_column_body">
    <xyz>0.15 0.0 0.13</xyz>
    <mass>0.01</mass>
    <ixx>0.001</ixx>
    <ixy>0.00</ixy>
    <ixz>0.00</ixz>
    <iyy>0.001</iyy>
    <iyz>0.00</iyz>
    <izz>0.001</izz>
    <cx>0.0</cx>
    <cy>0.0</cy>
    <cz>0.0</cz>
    <geom:box name="camera_column_geom">
      <xyz>0.02 0.00 0.0</xyz>
      <rpy>0 0 90</rpy>
      <size>0.11 0.11 0.03</size>
      <visual>
        <rpy>0 0 -90</rpy>
        <mesh>sonyvid30/sonyvid30_mid.mesh</mesh>
        <material>Gazebo/Black</material>
      </visual>
    </geom:box>
  </body:box>
  <body:box name="sonyvid30_top_body">
    <xyz>0.15 0.0 0.15</xyz>
    <mass>0.01</mass>
    <ixx>0.001</ixx>
    <ixy>0.00</ixy>
    <ixz>0.00</ixz>
    <iyy>0.001</iyy>
    <iyz>0.00</iyz>
    <izz>0.001</izz>
    <cx>0.0</cx>
    <cy>0.0</cy>
    <cz>0.0</cz>
    <geom:box name="camera_top_geom">
      <rpy>0 0 90</rpy>
      <size>0.12 0.119 0.03</size>
      <visual>
        <xyz>0.0 0.06 -0.015</xyz>
        <rpy>0 0 90</rpy>
        <mesh>sonyvid30/sonyvid30_top.mesh</mesh>
      </visual>
    </geom:box>
    <geom:cylinder name="camera_lens_geom">
      <xyz>0.045 -0.002 -0.002</xyz>
      <rpy>0 90 0</rpy>
      <size>0.01 0.04</size>
      <visual>
        <size>0.025 0.025 0.04</size>
        <material>Gazebo/White</material>
      </visual>
    </geom:cylinder>
    <sensor:camera name="sonyvid30_camera_sensor">
      <imageSize>320 240</imageSize>
      <hfov>60</hfov>
      <nearClip>0.1</nearClip>
      <farClip>50</farClip>
      <saveFrames>false</saveFrames>
      <saveFramePath>frames</saveFramePath>
      <controller:generic_camera name="sonyvid30_camera_controller">
        <interface:camera name="camera_iface_0"/>
      </controller:generic_camera>
    </sensor:camera>
  </body:box>
  <joint:hinge name="pan_joint">
    <body1>sonyvid30_body</body1>
    <body2>sonyvid30_column_body</body2>
    <anchor>sonyvid30_body</anchor>
    <axis>0 0 1</axis>
    <lowStop>-170</lowStop>
    <highStop>170</highStop>
    <erp>0.2</erp>
    <cfm>10e-5</cfm>
  </joint:hinge>
  <joint:hinge name="tilt_joint">
    <body1>sonyvid30_column_body</body1>
    <body2>sonyvid30_top_body</body2>
    <axis>0 1 0</axis>
    <lowStop>-20</lowStop>
    <highStop>20</highStop>
    <erp>0.2</erp>
    <cfm>10e-5</cfm>
  </joint:hinge>
  <controller:generic_ptz name="sonyvid30_controller">
    <panJoint>pan_joint</panJoint>
    <tiltJoint>tilt_joint</tiltJoint>
    <motionGain>1</motionGain>
    <force>0.001</force>
    <interface:ptz name="ptz_iface_1"/>
  </controller:generic_ptz>
    The include should be last within a model. All previous statements
    will override those in the included file
      <xi:include href="models/pioneer2dx.model" />
    </include>
  </model:physical>
  <!-- White Directional light -->
  <model:renderable name="directional_white">
    <xyz>2.0 0 2.0</xyz>
    <light>
      <type>spot</type>
      <spotCone>1000 1000 100</spotCone>
      <direction>-0.1 0 -0.9</direction>
      <diffuseColor>0.8 0.8 0.8</diffuseColor>
      <specularColor>0.1 0.1 0.1</specularColor>
      <range>10</range>
      <!-- Constant(0-1) Linear(0-1) Quadratic -->
      <attenuation>1.0 0.0 0</attenuation>
    </light>
  </model:renderable>
</gazebo:world>
one can potentially simplify above using xacro macros.
Originally posted by hsu with karma: 5780 on 2011-09-08
I just tested in electric, and the set_model_pose behavior is as expected.
set_model_pose in Diamondback also seems fine. Are you sure you have the latest debian release?
Try below?
sudo apt-get update
sudo apt-get upgrade
I should mention I am using pioneer2dx model from gazebo, i.e.:
rosrun gazebo gazebo `rospack find gazebo`/gazebo/share/gazebo/worlds/models/pioneer2dx.model
Originally posted by hsu with karma: 5780 on 2011-09-07
Yes, all packages are up to date. Gazebo package version is 1.2.8-s1312465587~natty. As mentioned it only works if it is a compound model, try "rosrun gazebo gazebo rospack find gazebo/gazebo/share/gazebo/worlds/pioneer2dx_camera.world" instead. But don't forget to disable gravity.
