[ rosmake ] rosdep install failed: Rosdep install failed
Traceback (most recent call last): File "/usr/local/bin/rosinstall", line 5, in pkg_resources.run_script('rosinstall==0.5.20', 'rosinstall') File "build/bdist.linux-i686/egg/pkg_resources.py", line 489, in run_script
File "build/bdist.linux-i686/egg/pkg_resources.py", line 1214, in run_script self.egg_info = os.path.join(path, 'EGG-INFO') File "/Library/Python/2.6/site-packages/rosinstall-0.5.20-py2.6.egg/EGG-INFO/scripts/rosinstall", line 599, in
File "/Library/Python/2.6/site-packages/rosinstall-0.5.20-py2.6.egg/EGG-INFO/scripts/rosinstall", line 590, in rosinstall_main
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/subprocess.py", line 462, in check_call raise CalledProcessError(retcode, cmd) subprocess.CalledProcessError: Command 'source /Users/brianriviere/ros/setup.sh && rosmake ros ros_comm --rosdep-install' returned non-zero exit status 1
Originally posted by brian on ROS Answers with karma: 1 on 2011-09-04
Could you maybe give more info on the context on which u get this
Originally posted by makokal with karma: 1295 on 2011-09-04
Comment by Mac on 2011-09-07:
If Macports can't build log4cxx, that's a MacPorts problem (and they provide a suggestion right there in the error message you posted).
Comment by brian on 2011-09-05:
Right now it is failing failing to install log4cxx using:
sudo port install log4cxx
To report a bug, see http://guide.macports.org/#project.tickets Failed to install log4cxx! [ rosmake ] rosdep install failed: Rosdep install failed
