There are some times that one of my service clients fails to get a response when it calls the service.
Are there any approaches or tools that can help my understanding of why this occasional failure occurs?
Both the server and client were written referring to the tutorials. They are run on the same machine and I was making calls at about 50Hz (a third node drives service calls between the client and the server and that node sends messages at 50Hz)
The error message I get is the "Failed to call the SensorService" until I abort the nodes. The messages always show up from the beginning, if they do show up. (Lending support to a start up issue, although one would think that eventually the service provider would start responding to service calls)
I reduced the loop rate to 10Hz and I haven't noticed a failed call in a while (but remember, it was occasional even at the higher loop rate). I did not use a persistent call. I just restart the launch file (a couple of times).
if (SensorClient_.call(SensorService))
    //Let the world know
    ROS_INFO("I called the SensorService!");
else
    ROS_ERROR("Failed to call the SensorService");
Originally posted by SL Remy on ROS Answers with karma: 2022 on 2011-08-27
Comment by Mac on 2011-09-02:
+1 for persistent connections; service calls are fairly expensive, and persistence helps a lot.
Comment by Pi Robot on 2011-08-29:
Likewise, can you edit your question and list the actual errors you receive from the service when the call fails? Also, how fast are you hitting the service? Like once a second, 50 times per second, once in awhile? You might get better results with a persistent service connection. I use a service to update the speed of my servos 20 times per second. At that rate, I can get connection failures to the service provider even when they are running on the same computer. However, when I make the service persistent, the errors go away. Persistent services using Python are described here (http://www.ros.org/wiki/rospy/Overview/Services#Persistent_connections) and for C++ look here (http://www.ros.org/wiki/roscpp/Overview/Services#Persistent_Connections).
Comment by Lorenz on 2011-08-29:
Can you give a little more information? Did you write the server? Is the server running on the same computer as the client?
Likewise, can you edit your question and list the actual errors you receive from the service when the call fails? Also, how fast are you hitting the service? Like once a second, 50 times per second, once in awhile? You might get better results with a persistent service connection. I use a service to update the speed of my servos 20 times per second. At that rate, I can get connection failures to the service provider even when they are running on the same computer. However, when I make the service persistent, the errors go away. Persistent services using Python are described here (http://www.ros.org/wiki/rospy/Overview/Services#Persistent_connections) and for C++ look here (http://www.ros.org/wiki/roscpp/Overview/Services#Persistent_Connections). - Pi Robot
Originally posted by Wim with karma: 2915 on 2011-09-12
The cause of the problem was a missing wait command: ros::service::waitForService("topic");
Because of this omission I caused a race hazard. Mischief managed.
Can this be added to C++ service client tutorial? (It's already in the python one.)
Originally posted by SL Remy with karma: 2022 on 2012-03-01
Comment by Mac on 2012-03-02:
It's a wiki...
