Hi All, I recently downloaded ros/electric.
I was trying to run openni node with command : roslaunch openni_launch openni.launch.
The result of this run is not stable. I get it to run at times and at other times, it just doesn't run.
It hangs and neither the topic /camera/depth_registered/points shows up anything with rostopic hz nor does rviz show anything.
Also, there is always an error I can see
[ERROR] [1314138567.670856122]: Tried to advertise a service that is already advertised in this node [/camera/depth_registered/image_rect_raw/compressed/set_parameters]
[ERROR] [1314138567.677972703]: Tried to advertise a service that is already advertised in this node [/camera/depth_registered/image_rect_raw/theora/set_parameters]
I have no clue why this error exists. It exists even when the node hangs and doesn't publish anything . I am using kinect. Any Help appreciated. ~Cheers! Neeraj
Originally posted by navderm on ROS Answers with karma: 78 on 2011-08-23
