I am modeling the Katana arm in Gazebo and use the pr2_controller_manager to control the joints. Everything works great except if I command a trajectory that (slowly) moves one joint past a certain point, the arm jumps around extremely violently.
Steps to reproduce (under Diamondback):
  • download and unzip this archive
  • rosmake katana_arm_gazebo
  • roslaunch katana_arm_gazebo katana_arm.launch # (be patient, it takes some time until Gazebo loads the arm model)
  • rosrun katana_arm_gazebo min_max_trajectory # to make the arm move up slowly
I also sometimes get the following error shortly after the jump, although that could be a side-effect rather than the cause of the arm jumping around:
gazebo: /tmp/buildd/ros-diamondback-visualization-common-1.4.2/debian/ros-diamondback-visualization-common/opt/ros/diamondback/stacks/visualization_common/ogre/build/ogre_src_v1-7-1/OgreMain/include/OgreAxisAlignedBox.h:252: void Ogre::AxisAlignedBox::setExtents(const Ogre::Vector3&, const Ogre::Vector3&): Assertion `(min.x <= max.x && min.y <= max.y && min.z <= max.z) && "The minimum corner of the box must be less than or equal to maximum corner"' failed.
Edit (in response to @hsu's answer):
Thank you @hsu, that solved my problem. Some observations:
  • Adding viscous joint damping to all joints always resulted in the gazebo crash mentioned above right when the arm model is spawned. (is this a bug?)
  • Adding viscious joint damping only to the offending joint didn't crash gazebo, but didn't fix the jumping behaviour either.
  • Changing the PID parameters to the values you suggested worked perfectly!
Originally posted by Martin Günther on ROS Answers with karma: 11816 on 2011-08-23
Comment by hsu on 2011-08-23:
Viscous damping can lead to numerical instability of the simulation integrator (not to be confused with dynamic instability of the pid controllers), looks like that might be what's happening when you added viscous damping. Reducing time step size will help, but that also fix the pid instability :-)
Pretty sure it's controller instability. I tried two things
  • reduced time step size from 1ms to 0.7ms
  • changed i-terms to 0 and reduced d-term by half.
more specifically, this controller yaml worked for me:
katana_arm_controller:
  type: "robot_mechanism_controllers/JointTrajectoryActionController"
  joints:
    - katana_motor1_pan_joint
    - katana_motor2_lift_joint
    - katana_motor3_lift_joint
    - katana_motor4_lift_joint
    - katana_motor5_wrist_roll_joint
  gains:
    katana_motor1_pan_joint: {p: 6.0, d: 4.0, i: 0.0, i_clamp: 0.3}
    katana_motor2_lift_joint: {p: 4.0, d: 3.0, i: 0.0, i_clamp: 0.3}
    katana_motor3_lift_joint: {p: 2.0, d: 1.5, i: 0.0, i_clamp: 0.3}
    katana_motor4_lift_joint: {p: 1.0, d: 1.0, i: 0.0, i_clamp: 0.3}
    katana_motor5_wrist_roll_joint: {p: 0.1, d: 0.05, i: 0.00, i_clamp: 0.01}
  joint_trajectory_action_node:
    joints:
    constraints:
      goal_time: 0.6
        goal: 0.02
        goal: 0.02
        goal: 0.02
        goal: 0.02
        goal: 0.02
Either one of these changes made the system stable. Alternatively, if the inertia values are correct and you wanted to keep the controller gains unmodified, you can play around with viscous joint damping by adding dynamics block to your urdf, e.g.:
<joint ...>
  <dynamics damping="1"/>
</joint>
Originally posted by hsu with karma: 5780 on 2011-08-23
