Hello
I'm trying to use the simulated kinect in gazebo, I just copy pasted the gazebo kinect snippet used in turtlebot and adapted it to my needs. the topic /camera/image_raw is publishing and I can see the image in rviz On the other hand no point cloud is being published on /camera/depth/points, The topic has been started, just no data are published on it. Any ideas? Regards, Moataz
Originally posted by Moataz Elmasry on ROS Answers with karma: 126 on 2011-08-18
Assuming you are on electric...
I am not sure about the missing image views in rviz, but w.r.t. the point clouds, you have just discovered a bug in the threshold logic based on connected clients in the gazebo_ros_camera plugin. It's fixed in trunk. One temporary hack around this bug is to:
1. make sure no one is subscribed to the image_raw ros topic. 1. now subscribe to the points topic
I'll shoot for a new release very soon. sorry about the breakage.
John
Originally posted by hsu with karma: 5780 on 2011-08-18
Comment by hsu on 2011-08-19:
I had originally fixed only gazebo_ros_camera, which would have not been enough... just pushed same changes for gazebo_ros_openni_kinect in trunk. Can someone else test it out and let me know it's working correctly before I make the final release? Thanks.
Comment by Moataz Elmasry on 2011-08-18:
when do you expect this fix to appear on unstable ubuntu repo?
are you talking about the snippet gazebo_ros_openni_kinect.cpp::updatechild(). if (!this->myParent->IsActive()) { // do this first so there's chance for sensor to run 1 frame after activate if (this->pointCloudConnectCount > 0) { this->myParent->SetActive(true); this->myParent->SimulateDepthData(true); } else if (this->imageConnectCount > 0) { this->myParent->SimulateDepthData(false); this->myParent->SetActive(true); } }
Are you running on electric or diamondback? The kinect plugin is only available in electric and not in diamondback.
Originally posted by mmwise with karma: 8372 on 2011-08-18
I´m running on unstable
