My cad translate to stl file is image description
I use meshlab to view it:
image description
But when I import to gazebo.
 sam@/home/sam/code/ros/gazebo/stl$ rosrun gazebo spawn_model -file      `pwd`/foot.urdf -urdf -model foot_model -z 100.5
 loading model xml from file
 attempting to spawn robot in simulation
 waiting for service spawn_urdf_model
 spawn status:  SpawnModel: successfully spawned model
 spawning success True
The model seems very weird even broken to parts.
image description
How to solve it? Thank you~~
Originally posted by sam on ROS Answers with karma: 2570 on 2011-08-13
Comment by sam on 2011-08-21:
I have added the picture in meshlab, and I also upload the stl file: http://www.adrive.com/public/8796d1359372a369f97531afc9a972ad728f8e47d46b8746e2a3242b27619be4.html
Comment by hsu on 2011-08-15:
you can try and import the stl file with some other mesh editors such as meshlab or wings3d (or blender if the top image was not a stl import). If things look ok there, can you post the STL file? thanks.
Comment by sam on 2011-08-15:
Single STL. I haven't tried Multiple STL's connected by joints.
Hi Sam, is this a single STL? Multiple STL's connected by joints?
It looks like the mesh contains faces that are not 2-manifolds. I recommend shrink-wrapping the mesh with one of the modern cad packages.
Originally posted by hsu with karma: 5780 on 2011-08-24
Comment by sam on 2011-08-25:
Autodesk Inventor Professional 2012.
Comment by hsu on 2011-08-24:
what software are you using to generate STL from CAD model?
Comment by sam on 2011-08-24:
I already use the smallest resolution option of stl export.Is there any other way to shrink-wrapping the mesh? Or how to import it to gazebo correctly?
