I had pr2 robot running in gazebo.
I want to get the pose of r_wrist_roll_link with respect to base_link but got an error here.
$ rosrun tf tf_echo base_link r_wrist_roll_link
Failure at 146370.940000000
Exception thrown:Frame id /base_link does not exist! When trying to transform between   /r_wrist_roll_link and /base_link.
The current list of frames is:
At time 146371.172
- Translation: [0.590, -0.360, 0.930]
- Rotation: in Quaternion [0.651, -0.211, 0.381, 0.621]
        in RPY [1.475, -0.860, 0.310]
At time 146371.202
- Rotation: in Quaternion [0.652, -0.210, 0.381, 0.621]
Any idea what's the problem?
[UPDATE] It seems that it just can't find tf from base_link to r_wrist_roll_link at first, but then it gives the correct transform. I wrote some code to check the transform,
// get the position of r_wrist_roll_link
ros::Duration(0.1).sleep();
tf::StampedTransform transform;
try{
  listener.lookupTransform("base_link", "r_wrist_roll_link",
                           ros::Time(0), transform);
catch (tf::TransformException ex){
  ROS_ERROR("%s",ex.what());
It works fine but if I comment out the line ros::Duration(0.1).sleep(), it gives same error as in tf_echo. Maybe it's because transform listener needs some time to get some frames. Not sure if that's the problem of tf_echo.
Here is the output of roswtf and view_frames shows both base_link and r_wrist_roll_link.
Loaded plugin tf.tfwtf
Package: supercontroller_keyboard
Static checks summary:
Found 1 warning(s).
Warnings are things that may be just fine, but are sometimes at fault
WARNING The following packages have msg/srv-related cflags exports that are no longer necessary
    <export>
        <cpp cflags="..."
    </export>:
 * motion_planning_msgs: -I${prefix}/msg/cpp -I${prefix}/srv/cpp
 * kinematics_msgs: -I${prefix}/msg/cpp -I${prefix}/srv/cpp
 * geometric_shapes_msgs: -I${prefix}/msg/cpp
 * mapping_msgs: -I${prefix}/msg/cpp
Beginning tests of your ROS graph. These may take awhile...
analyzing graph...
... done analyzing graph
running graph rules...
... done running graph rules
running tf checks, this will take a second...
... tf checks complete
Online checks summary:
Found 3 warning(s).
WARNING The following node subscriptions are unconnected:
 * /head_traj_controller/point_head_action:
   * /head_traj_controller/point_head_action/cancel
   * /head_traj_controller/point_head_action/goal
 * /l_gripper_controller/gripper_action_node:
   * /l_gripper_controller/gripper_action/cancel
   * /l_gripper_controller/gripper_action/goal
 * /gazebo:
   * /head_traj_controller/joint_trajectory_action/cancel
   * /r_arm_controller/joint_trajectory_action/goal
   * /gazebo/set_link_state
   * /l_arm_controller/command
   * /projector_wg6802418_controller/image
   * /set_hfov
   * /torso_controller/joint_trajectory_action/cancel
   * /torso_controller/joint_trajectory_action/goal
   * /plugged_in    ================================================================================
analyzing graph...
Found 3 warning(s).
 * /gazebo:
   * /set_hfov
   * /plugged_in
   * /l_arm_controller/joint_trajectory_action/goal
   * /torso_controller/follow_joint_trajectory/goal
   * /head_traj_controller/follow_joint_trajectory/cancel
   * /base_controller/command
   * /head_traj_controller/joint_trajectory_action/goal
   * /r_arm_controller/joint_trajectory_action/cancel
   * /torso_controller/follow_joint_trajectory/cancel
   * /l_arm_controller/joint_trajectory_action/cancel
   * /r_arm_controller/follow_joint_trajectory/cancel
   * /l_arm_controller/follow_joint_trajectory/goal
   * /head_traj_controller/follow_joint_trajectory/goal
   * /r_arm_controller/follow_joint_trajectory/goal
   * /r_arm_controller/command
   * /gazebo/set_model_state
   * /set_update_rate
   * /laser_tilt_controller/set_periodic_cmd
   * /laser_tilt_controller/set_traj_cmd
   * /l_arm_controller/follow_joint_trajectory/cancel
 * /torso_controller/position_joint_action_node:
   * /torso_controller/position_joint_action/goal
   * /torso_controller/position_joint_action/cancel
 * /pr2_dashboard_aggregator:
   * /pr2_etherCAT/motors_halted
   * /ddwrt/accesspoint
   * /power_board/state
 * /r_gripper_controller/gripper_action_node:
   * /r_gripper_controller/gripper_action/goal
   * /r_gripper_controller/gripper_action/cancel
 * /rviz_1312398084466095825:
   * /visualization_marker_array
 * /tf2_buffer_server:
   * /tf2_buffer_server/goal
   * /tf_static
   * /tf2_buffer_server/cancel
WARNING The following nodes are unexpectedly connected:
 * /torso_controller/position_joint_action_node->/rosout (/rosout)
 * /rviz_1312398084466095825->/rosout (/rosout)
 * /pr2_right_arm_kinematics->/rosout (/rosout)
 * /gazebo->/tf_echo_1312905336085059997 (/tf)
 * /tilt_hokuyo_node->/rosout (/rosout)
 * /base_hokuyo_node->/rosout (/rosout)
 * /camera_synchronizer_node->/rosout (/rosout)
 * /wide_stereo/wide_stereo_proc->/rosout (/rosout)
 * /l_forearm_cam/image_proc->/rosout (/rosout)
 * /narrow_stereo_textured/narrow_stereo_textured_proc->/rosout (/rosout)
 * /default_controllers_spawner->/rosout (/rosout)
 * /tf2_buffer_server->/rosout (/rosout)
 * /l_gripper_controller/gripper_action_node->/rosout (/rosout)
 * /r_gripper_controller/gripper_action_node->/rosout (/rosout)
 * /narrow_stereo/narrow_stereo_proc->/rosout (/rosout)
 * /pr2_mechanism_diagnostics->/rosout (/rosout)
 * /head_traj_controller/point_head_action->/rosout (/rosout)
 * /gazebo->/rosout (/rosout)
 * /robot_state_publisher->/rosout (/rosout)
 * /tf_echo_1312905346888907263->/rosout (/rosout)
 * /r_forearm_cam/image_proc->/rosout (/rosout)
 * /robot_pose_ekf->/rosout (/rosout)
 * /diag_agg->/rosout (/rosout)
 * /rxconsole_1312398154858191094->/rosout (/rosout)
 * /pr2_dashboard_aggregator->/rosout (/rosout)
 * /gazebo->/tf_echo_1312905342410323167 (/tf)
WARNING These nodes have died:
 * spawn_pr2_model-3
   * /set_update_rate
   * /tf_static
 * spawn_pr2_model-3
Originally posted by vincent on ROS Answers with karma: 311 on 2011-08-09
Comment by vincent on 2011-08-09:
i've updated it
Comment by dornhege on 2011-08-09:
Nobody publishes a /base_link transform. The simulation does this if working correctly. Can you add the output of roswtf and rosrun tf view_frames?
You said it already in your post. The listener needs to get the information first before it can transform.
Instead of the sleep you can use: waitForTransform.
Originally posted by dornhege with karma: 31395 on 2011-08-09
Post score: 6
thank you. yes i think hsu is right, since waitForTransform() did fail sometimes from my experience as well
Comment by hsu on 2011-08-09:
from past experience, I remeber Transformer::waitForTransform(...) sometimes returns false and does not block, so you need while loop around the call.
