Hi,
I am almost going crazy ... I analyse a bag file and monitor a strange behaviour. When I use the code below I have to comment one of rospy.Subscriber(...) lines. Otherwise the Program gets no message and rxgraph shows no connection. But with only one subscriber (regardless of which) the code works well!
What is wrong in my idea?
Best wishes from Germany Enjoy the weekend
Poseidonius
import roslib; roslib.load_manifest('Localization')
import rospy
from std_msgs.msg import Float32
def callback(event, index):
     print index
rospy.init_node('OdoMapper')
rospy.Subscriber("/OdoLeft", Float32, callback, 0) # one of them have to be commented
rospy.Subscriber("/OdoRight", Float32, callback, 1)
rospy.spin()
Originally posted by Poseidonius on ROS Answers with karma: 427 on 2011-08-05
Comment by dornhege on 2011-08-08:
Another test, just to verify: Does this only happen on the bag file? If you do 2x rostopic pub, does everything work OK?
Strange, indeed. Although I don't use Fedora, I would assume that it is not Fedora itself, but the system setup. Can you check the network setup tfoote posted below even on the local machine?
Comment by Poseidonius on 2011-08-08:
Strange - on a Ubuntu PC the code works fine, just my Fedora presents the mentioned behaviour
Comment by tfoote on 2011-08-06:
Can you add the output of roswtf to your question?
no activity in a month, closing
Originally posted by kwc with karma: 12244 on 2011-09-02
