Hello,
I've been working a little with ROS but I have some doubts. I'm trying to figure out how many messages do I receive per second from a topic to which I'm subscribed. I suppose it depends of the speed with which they're published by the node. I'm talking about the openni_camera node and the "camera/rgb/points" topic. Please tell me if I'm getting this alright:
Here's a typical main for a node:
int main (int argc, char** argv) {
// Initialize ROS
ros::init (argc, argv, "sergio_filter");
ros::NodeHandle nh;
// Create a ROS subscriber for the input point cloud
ros::Subscriber sub = nh.subscribe ("camera/rgb/points", 10, cloud_cb);
// Spin
ros::spin (); }
So, the cloud_cb is a callback function that is called each time a message from the subscribed topic is received, right? I did a simple study of the time that is takes to receive 1, 10 and 100 messages from the openni_camera and I got some unstable results =P. For example, to receive 10 sensor_msgs::PointCloud2 it takes between 0.444811 and 0.507768 seconds, so we could say that I receive ~20 msgs per sec. I guess this variation in time depends of the number of points that the Kinect is able to get in the pointcloud at a given time.
Isn't there any elegant ROS way or configuration to just "listen" to, let's say, 2 messages per second? Other than just using an:
void cloud_cb (const sensor_msgs::PointCloud2ConstPtr& input) {
if(i==10){ processing algorithm i=0; } else{ do nothing } i++; }
Given that my Point Cloud Library based algorithm isn't (for now) very fast, 20 pointclouds per second would be too much.
Let's say that my algorithm inside the cloud_cb callback function takes a whole second to complete. During this time my node is deaf to the other sensor_msgs::PointCloud2? Just one cloud_cb function can run at a time right? No parallel processing here. If I use a subscriber's buffer of 1, then when my cloud_cb function finishes, another instance will pop up with the NEXT message that arrives, right? While if I use a buffer of 50, it'll pop up with the next message in the queue.
Am I getting all this alright ?
Thank you for any help!
Best Regards,
Originally posted by Sergio MP on ROS Answers with karma: 182 on 2011-08-01
First, for your tests there is a simple tool: rostopic hz will tell you the data-rate a topic is published at.
For your actual problem: Yes, there is an elegant way to limit the topic to, e.g. 2 msg/s = 0.5Hz. You can use the throttle tool in topic_tools that will republish a given topic at a specific rate. You then subscribe the ..._throttle topic at a lower rate.
For the case of pointclouds a nodelet will be more efficient. Here is an example launch file that uses a nodelet to throttle the topic. I'm not sure if there is a nodelet throttle yet.
Regarding threading: Yes, as long as you don't spin your callback is not called anymore and the queue will fill up. On the other hand you can put the spinning in another thread and not miss messages. It's just a matter of what behavior you want. The article about Callbacks and Spinning contains more detail about this.
Originally posted by dornhege with karma: 31395 on 2011-08-01
