I am making a node that receives transforms from openni_tracker. Is there a way to make my node distinguish between transforms being sent for User 1, User 2, etc...?
Originally posted by qdocehf on ROS Answers with karma: 208 on 2011-07-18
Comment by qdocehf on 2011-07-29:
If editing the ROS source code is a bad idea, do you have any other suggestions for solving this problem?
I am running the latest version of diamondback. How do I even install electric-turtle? When I went to the installation page, diamondback was the only option it gave me.
Comment by Asomerville on 2011-07-28:
"Anyways, I am running the latest version of ROS" By which you mean latest diamondback version? latest electric-turtle version? latest unstable trunk head version?
If you wanted mainting the change as ROS got updated, you'd have to: 1) be certain that your change doesn't cause unforeseen consequences 1) continually make sure it worked with future versions. 2) be ok with your software only working with your custom verson of ROS
Comment by qdocehf on 2011-07-28:
Also, what kind of maintenance problems would there be? It seems like it would be a pretty small change, but I guess I do not know what the effects of it would be.
The lines that my version is missing have no pertinence to this question. It was just something that I noticed while looking at Bemfica's answer. Anyways, I am running the latest version of ROS.
It would generally be a bad idea because it would be a maintenance nightmare for you. It would probably be much easier/better to just upgrade to the latest version of ROS since tfoote suggested it has the feature you're looking for.
Would editing the openni_tracker.cpp file to send an index with each transform to specify which user's data is being sent be fine? Or is it a bad idea to edit ROS code? I know that it is supposed to be read-only.
Comment by Asomerville on 2011-07-18:
I tried to improve your title, but not sure if I interpreted you correctly. Please look at it and correct it if necessary.
no activity in > 1 month, closing
Originally posted by kwc with karma: 12244 on 2011-09-02
The users transforms are all published as you can see on the API. You could write a subscriber to read it. But something makes me think that there is an easier way to do it.
Originally posted by Bemfica with karma: 482 on 2011-07-18
Comment by qdocehf on 2011-07-19:
I downloaded diamondback just under a month ago. The differences are not so important to me though.
Comment by tfoote on 2011-07-19:
What version have you downloaded? The online docs are generated from the newest version. Which suggests that this feature will be in the next release.
Comment by qdocehf on 2011-07-18:
I just noticed that the code in your link is different from that of openni_tracker.cpp, the file that I got from downloading ROS. openni_tracker.cpp is missing lines 77, 78, 85, 86, 87, 88, 89, and 91. Also, lines 82 and 93 are slightly different.
I already have it set up to receive the transforms. My problem is that I am not sure how to differentiate between the head for User 1, the head for User 2, the head for User 3, etc...
