Because I use a launch file to launch many nodes. If there exist any method to output the message with corresponding node name, it will be easier to debug. Thank you~
example of unknown node name
[ WARN] [1310816065.685614719]: Costmap2DROS transform timeout. Current time: 1310816065.6855, global_pose stamp: 1310816065.0186, tolerance: 0.3000
Originally posted by sam on ROS Answers with karma: 2570 on 2011-07-15
