Hello, all,
Recently, we've been attempting to access the kinect depth data from the published point cloud provided by the openni_node, but we've run into a couple stumbling points:
first, the ros tutorial for pcl_ros
http://www.ros.org/wiki/pcl_ros/Tutorials/CloudToImage
references a topic published by openni called: /camera/depth/points2 but our version of openni_kinect only publishes: /camera/depth/points Are we using an outdated version?
Also, we tried working with /camera/depth/points and we believe that this information is published in binary format. When we attempted to convert the binary format of a single point to x,y,z information though, we received a list of 4 integers. Are we interpreting the information incorrectly?
We also subscribed to the /camera/depth/image, and we could access the depth information from a single point, but we're restricted to meter-by-meter resolution. Is there a better way of getting more resolution with the /camera/depth/image ?
Thanks for reading, and we appreciate any directions you can point us to accessing the depth information (of points) from the kinect.
Sincerely,
Poofjunior
Originally posted by Poofjunior on ROS Answers with karma: 88 on 2011-07-13
