I am writing a node, and I am trying to use the ROS and tf tutorials to help me. When I try to compile the .cpp file, the files that I have included, such as
#include <ros/ros.h>
#include <ros/package.h>
cannot be found. Am I supposed to include these under different names?
This is my CMakeLists.txt:
cmake_minimum_required(VERSION 2.4.6)
include($ENV{ROS_ROOT}/core/rosbuild/rosbuild.cmake)
# Set the build type.  Options are:
#  Coverage       : w/ debug symbols, w/o optimization, w/ code-coverage
#  Debug          : w/ debug symbols, w/o optimization
#  Release        : w/o debug symbols, w/ optimization
#  RelWithDebInfo : w/ debug symbols, w/ optimization
#  MinSizeRel     : w/o debug symbols, w/ optimization, stripped binaries
#set(ROS_BUILD_TYPE RelWithDebInfo)
rosbuild_init()
#set the default path for built executables to the "bin" directory
set(EXECUTABLE_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/bin)
#set the default path for built libraries to the "lib" directory
set(LIBRARY_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/lib)
#uncomment if you have defined messages
#rosbuild_genmsg()
#uncomment if you have defined services
#rosbuild_gensrv()
#common commands for building c++ executables and libraries
#rosbuild_add_library(${PROJECT_NAME} src/example.cpp)
#target_link_libraries(${PROJECT_NAME} another_library)
#rosbuild_add_boost_directories()
#rosbuild_link_boost(${PROJECT_NAME} thread)
#rosbuild_add_executable(example examples/example.cpp)
#target_link_libraries(example ${PROJECT_NAME})
rosbuild_add_executable(SkeletonTracker src/SkeletonTracker.cpp)
This is my manifest.xml:
<package>
  <description brief="skeletonTracker">
     skeletonTracker
  </description>
  <author>robot</author>
  <license>BSD</license>
  <review status="unreviewed" notes=""/>
  <url>http://ros.org/wiki/skeletonTracker</url>
  <depend package="std_msgs"/>
  <depend package="rospy"/>
  <depend package="roscpp"/>
</package>
If I try to use rosmake to build the package, this is output:
robot@neutronstar:~/SkeletonTracking/skeletonTracker$ rosmake
[ rosmake ] No package specified.  Building ['skeletonTracker']
[ rosmake ] Packages requested are: ['skeletonTracker']
[ rosmake ] Logging to directory/home/robot/.ros/rosmake/rosmake_output-20110713-134607
[ rosmake ] Expanded args ['skeletonTracker'] to:
['skeletonTracker']
[ rosmake ] Checking rosdeps compliance for packages skeletonTracker.  This may take a few seconds.
[ rosmake ] rosdep check passed all system dependencies in packages
[rosmake-0] Starting >>> roslib [ make ]
[rosmake-0] Finished <<< roslib ROS_NOBUILD in package roslib
[rosmake-1] Starting >>> rosgraph_msgs [ make ]
[rosmake-1] Finished <<< rosgraph_msgs ROS_NOBUILD in package rosgraph_msgs
[rosmake-2] Starting >>> rosbuild [ make ]
[rosmake-2] Finished <<< rosbuild ROS_NOBUILD in package rosbuild
 No Makefile in package rosbuild
[rosmake-3] Starting >>> cpp_common [ make ]
[rosmake-0] Starting >>> std_msgs [ make ]
[rosmake-1] Starting >>> roslang [ make ]
[rosmake-3] Finished <<< cpp_common ROS_NOBUILD in package cpp_common
[rosmake-0] Finished <<< std_msgs ROS_NOBUILD in package std_msgs
[rosmake-1] Finished <<< roslang ROS_NOBUILD in package roslang
 No Makefile in package roslang
[rosmake-2] Starting >>> xmlrpcpp [ make ]
[rosmake-0] Starting >>> roscpp_traits [ make ]
[rosmake-1] Starting >>> rostime [ make ]
[rosmake-2] Finished <<< xmlrpcpp ROS_NOBUILD in package xmlrpcpp
[rosmake-3] Starting >>> rospy [ make ]
[rosmake-1] Finished <<< rostime ROS_NOBUILD in package rostime
[rosmake-3] Finished <<< rospy ROS_NOBUILD in package rospy
[rosmake-0] Finished <<< roscpp_traits ROS_NOBUILD in package roscpp_traits
[rosmake-1] Starting >>> roscpp_serialization [ make ]
[rosmake-3] Starting >>> rosconsole [ make ]
[rosmake-3] Finished <<< rosconsole ROS_NOBUILD in package rosconsole
[rosmake-1] Finished <<< roscpp_serialization ROS_NOBUILD in package roscpp_serialization
[rosmake-1] Starting >>> roscpp [ make ]
[rosmake-1] Finished <<< roscpp ROS_NOBUILD in package roscpp
[rosmake-1] Starting >>> skeletonTracker [ make ]
[ rosmake ] Last 40 lineseletonTracker: 2.8 sec ]    [ 1 Active 14/15 Complete ]
  make[3]: Leaving directory `/home/robot/SkeletonTracking/skeletonTracker/build'
  [  0%] Built target rospack_genmsg_libexe
  make[3]: Entering directory `/home/robot/SkeletonTracking/skeletonTracker/build'
  [  0%] Built target rosbuild_precompile
  [100%] Building CXX object CMakeFiles/SkeletonTracker.dir/src/SkeletonTracker.o
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:4:38: error: tf/transform_broadcaster.h: No such file or directory
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:5:35: error: tf/transform_listener.h: No such file or directory
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:6:25: error: tf/frames.hpp: No such file or directory
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:7:22: error: XnOpenNI.h: No such file or directory
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:8:24: error: XnCodecIDs.h: No such file or directory
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:9:26: error: XnCppWrapper.h: No such file or directory
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp: In function ‘int main(int, char**)’:
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:13: error: ‘ros_init’ was not declared in this scope
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:14: error: ‘Node’ is not a member of ‘ros’
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:14: error: expected ‘;’ before ‘Handle’
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:15: error: ‘tf’ has not been declared
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:15: error: expected ‘;’ before ‘listener’
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:17: error: ‘node’ was not declared in this scope
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:18: error: ‘tf’ has not been declared
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:18: error: expected ‘;’ before ‘transform’
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:20: error: ‘listener’ was not declared in this scope
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:21: error: expected ‘;’ before ‘}’ token
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:22: error: expected type-specifier before ‘tf’
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:22: error: expected ‘)’ before ‘::’ token
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:22: error: expected ‘{’ before ‘::’ token
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:22: error: ‘::TransformException’ has not been declared
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:22: error: expected ‘;’ before ‘ex’
  /home/robot/SkeletonTracking/skeletonTracker/src/SkeletonTracker.cpp:29: error: expected ‘}’ at end of input
  make[3]: *** [CMakeFiles/SkeletonTracker.dir/src/SkeletonTracker.o] Error 1
  make[2]: *** [CMakeFiles/SkeletonTracker.dir/all] Error 2
  make[2]: Leaving directory `/home/robot/SkeletonTracking/skeletonTracker/build'
  make[1]: *** [all] Error 2
  make[1]: Leaving directory `/home/robot/SkeletonTracking/skeletonTracker/build'
[ rosmake ] Output from build of package skeletonTracker written to:
[ rosmake ]    /home/robot/.ros/rosmake/rosmake_output-20110713-134607/skeletonTracker/build_output.log
[rosmake-1] Finished <<< skeletonTracker [FAIL] [ 2.87 seconds ]
[ rosmake ] Halting due to failure in package skeletonTracker.
[ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 15 packages with 1 failures.
[ rosmake ] Summary output to directory
Originally posted by qdocehf on ROS Answers with karma: 208 on 2011-07-13
Comment by arebgun on 2011-07-13:
See my updated answer.
Comment by qdocehf on 2011-07-13:
Currently, the only dependencies I still need are for tf/frames.hpp and Xn header files.
How do I find the settings of ROS_ROOT and ROS_PACKAGE_PATH?
Comment by dornhege on 2011-07-13:
Can you also add the settings of ROS_ROOT and ROS_PACKAGE_PATH + the exact error output.
3 Answers 3
Your description and error output say two completely different things. Judging from the output transform_broadcaster.h can't be found, for that you need to depend on tf package. When you add that dependency to your manifest it should compile, provided there are no other errors.
<depend package="tf"/>
tf/frames.hpp include file does not exist, you probably meant kdl/frames.hpp.
<depend package="kdl"/>
To use Xn* headers you need to depend on nite and openni packages.
<depend package="nite"/>
<depend package="openni"/>
Originally posted by arebgun with karma: 2121 on 2011-07-13
Comment by qdocehf on 2011-07-15:
He edited it after I made the comment.
Comment by Asomerville on 2011-07-14:
@qdocehf... he did include the lines. OpenNI.
Could you give me exactly what I need to add to the manifest.xml file for the Xn headers()? I do not know where to find it, and it does not fit the pattern of the others.
Sorry, the ros headers had not been working earlier, so I did not check when I uploaded the errors.
I believe ros/ros.h is part of the roscpp package.
Are you using the ROS Build System? You need to include roscpp as a dependency in the manifest.xml of the package you are building:
Originally posted by Ivan Dryanovski with karma: 4954 on 2011-07-13
Comment by Ivan Dryanovski on 2011-07-13:
Can you share your CMakeLists.txt and manifest.xml? Also, does "roscd roscpp" take you to the correct folder?
Yes, this was already in my manifest.xml
From your output, it looks like you need to add a tf dependency in the manifest.xml file, i;e
let us know if there are more errors
tf/frames.hpp and the Xn header files (XnOpenNI.h; XnCodeIDs.h; XnCppWrapper.h) still cannot be found. Which dependencies do I need for those?
