I have a launch file launching several nodes and I'm interested on saving a certain configuration of warn/debug/info depending on the node. Is it possible to save a specific configuration or a way of launching it setting the levels accordingly other than changing them manually at every execution?
Originally posted by quimnuss on ROS Answers with karma: 169 on 2011-07-12
Yes. You can set the ROSCONSOLE_CONFIG_FILE environment variable and have that point to a custom log4cxx config that sets the loggerlevels how you want it.
I guess you want to set debug for your package enabled, then use this entry:
log4j.logger.ros.PACKAGE=DEBUG
Originally posted by dornhege with karma: 31395 on 2011-07-12
Post score: 4
Comment by bhaskara on 2011-07-14:
There's a ros-specific example at http://www.ros.org/wiki/rosconsole#Configuration. Rospy uses a different system based on the Python logging module, described here: http://www.ros.org/wiki/rospy/Overview/Logging. At the bottom of the page it describes how to set up a config file for this.
Comment by Lorenz on 2011-07-13:
Actually, since roscpp is using log4cxx, its documentation on the config file format might be the right one: http://logging.apache.org/log4cxx/index.html. Im not sure if this approach works for rospy though since it doesn't use log4cxx.
Comment by dornhege on 2011-07-13:
There is an example in my post. To check syntax and specifics about rosconsole, click the link in my post and then also look at rosconsole. It's in rosconsole, so I would guess it is loaded in node init.
Comment by quimnuss on 2011-07-13:
Looks like it! So I'd have to create a config file and point the ROSCONSOLE_CONFIG_FILE to it. Where can I find the syntax or an example of a config file? When is it loaded? when roscore is launched? when rxconsole is launched? (I'm sorry the documentation about the subject is too scarce...)
