Hello ROS Wizards,
I am trying out the new (and incredibly awesome) arm navigation planning wizard on my home built robot (Pi Robot). The wizard runs flawlessly and I generated a planning group called "left arm" that runs from the torso link to the left hand link.
Next I wanted to try the planning components visualizer so I launched the automatically created planning_components_visualizer.launch file. Most of the nodes fired up fine until I ran into the following error:
No default planner configuration defined under 'default_planner_config'. A default planner must be defined from among the configured planners
The full output from the launch file looks like this:
core service [/rosout] found
process[wall_clock_server-1]: started with pid [2005]
process[environment_server-2]: started with pid [2006]
process[planning_scene_validity_server-3]: started with pid [2007]
process[pi_robot_left_arm_kinematics-4]: started with pid [2008]
process[ompl_planning-5]: started with pid [2009]
process[trajectory_filter_server-6]: started with pid [2010]
process[rviz_planning_components-7]: started with pid [2011]
process[planning_components_visualizer-8]: started with pid [2012]
process[rob_st_pub-9]: started with pid [2013]
[ INFO] [1310134526.200470474, 1310134526.196687936]: Environment server started
[ INFO] [1310134526.269147358, 1310134526.258922100]: waitForService: Service [/ompl_planning/plan_kinematic_path] has not been advertised, waiting...
[ INFO] [1310134526.544622151, 1310134526.542999029]: Successfully connected to planning scene action server for /planning_scene_validity_server
[ INFO] [1310134526.544764147, 1310134526.542999029]: Successfully connected to planning scene action server for /ompl_planning
[ INFO] [1310134526.746567756, 1310134526.741112947]: Successfully connected to planning scene action server for /pi_robot_left_arm_kinematics
[ INFO] [1310134526.848666707, 1310134526.845432043]: Successfully connected to planning scene action server for /trajectory_filter_server
[ INFO] [1310134527.267298212, 1310134527.264225959]: Waiting for planner service /ompl_planning/plan_kinematic_path
[ INFO] [1310134527.268940800, 1310134527.264225959]: waitForService: Service [/ompl_planning/plan_kinematic_path] has not been advertised, waiting...
[ERROR] [1310134527.285647063, 1310134527.274550914]: No default planner configuration defined under 'default_planner_config'. A default planner must be defined from among the configured planners
Any thoughts on how I can fix this?
Thanks!
patrick
Originally posted by Pi Robot on ROS Answers with karma: 4046 on 2011-07-08
Add the following line at the end of your auto-generated YAML configuration file for OMPL (config/ompl_planning.yaml):
default_planner_config: SBLkConfig1
We'll update the gui soon so it reflects this change and adds the line in automatically.
Originally posted by Sachin Chitta with karma: 1304 on 2011-07-08
Comment by egiljones on 2011-07-11:
Fixed on trunk, will be released shortly. Sorry for the omission!
Comment by Pi Robot on 2011-07-08:
Thanks Sachin--works like a charm now!
