Hi,
I am trying to get the result of a JointTrajectoryAction. The my_joint_trajecotry_action_client.get_result() returns a message of type JointTrajectoryResult, but it has no meaningful fields. What's the right way to get the result of a JointTrajectoryAction?
Thanks!
Huan
Originally posted by liuhuanjim013 on ROS Answers with karma: 152 on 2011-06-23
I'm not familiar with using JointTrajectoryAction in particular, but according to the docs, the result is supposed to be empty. This means that you would use the state of the ActionClient to determine the result of your command to the controller. For example, some states that you could get (e.g. with my_joint_trajectory_action_client.get_state() ) could be GoalStatus.SUCCEEDED or GoalStatus.ABORTED. There are other states that you could get; see the actionlib docs for details.
Originally posted by Eric Perko with karma: 8406 on 2011-06-23
Comment by liuhuanjim013 on 2011-06-23:
Thanks Eric! This is exactly what I need :)
