Due to the hardware limitation, the robot did not follow the trajectory as we send via joint_trajectory_action, especially for a torso_controller/joint_trajectory_action of spine joint. We'd like to wait the program until the pr2 torso movement has finished. Currently, the robot send back failed status/result after the commanded time period, but the robot still continue to move. Is there a way to know if the robot still moving joint or finished interpolation.
Originally posted by Kei Okada on ROS Answers with karma: 1186 on 2011-06-23
have you tried your_action_client.wait_for_result() or your_action_client.send_goal_and_wait() (in python)?
Originally posted by liuhuanjim013 with karma: 152 on 2011-06-23
Comment by tfoote on 2011-07-06:
It sounds like this would work fine if you made your planner plan feasible plans with timeouts which would not be broken in normal operations.
Comment by liuhuanjim013 on 2011-06-24:
I see. So you used your_action_client.get_state()? I also do this to see if the trajectory has completed: print 'arm action state:',actionlib.get_name_of_constant(actionlib.GoalStatus,arm_joint_action_client.get_state()). But you are right, sometimes the robot doesn't complete the trajectory.
Comment by Kei Okada on 2011-06-24:
send_goal_and_wait returns with aborted after commanded period has passed, but if the period is too small, say 1 sec for 300mm up of spine joint, the robot continue moving towards the original goal. I'd like to know when the robot reached that point.
