Previously, I posted how to get started on the point cloud data for the Openni. Many of you posted that i need to get through the tutorials for ROS to have a better understanding. I have done that now.One posted this code(for the subscriber) for me... which was very helpful.I have some qns on this code:
  1. We need to have both a publisher and subscriber node for the Kinect in order to get point cloud data.Am i right to say that?
  2. how do u get the depth data from the point cloud data?
Really need of help. I am sorry if i ask stupid questions.
    #include <ros/ros.h>
    #include <pcl_ros/point_cloud.h>
    #include <sensor_msgs/PointCloud2.h>
using namespace ros;
using namespace sensor_msgs;
class processPoint {
    NodeHandle nh;
    Subscriber sub;
public:
    processPoint() {
        sub = nh.subscribe<sensor_msgs::PointCloud2>("/camera/rgb/points", 1, &processPoint::processCloud, this);
    ~processPoint() {
    void processCloud( const sensor_msgs::PointCloud2ConstPtr& cloud );
void processPoint::processCloud( const sensor_msgs::PointCloud2ConstPtr& cloud ) {
int main(int argc, char **argv) {
    init(argc, argv, "processPoint");
    processPoint processPoint;
    Rate spin_rate(1);
    while( ok() ) {
        spinOnce();
        spin_rate.sleep();
Originally posted by lakshmen on ROS Answers with karma: 101 on 2011-06-14
Comment by lakshmen on 2011-06-15:
hi ppl ... is the page that give the correct code for point cloud : http://www.ros.org/wiki/pcl_ros
Are you working with ROS node system or do you want to read in the pointcloud from a single c/cpp file?
  • In the first case you should roslaunch the openni_camera openni_node.launch file. This will publish the pointclouds on the /camera/rgb/points or /camera/depth/points topics (depending if you want XYZ or XYZRGB pointcloud). Look at roslaunch and the openni camera package.
  • In the second case you should look at the PCL library (pointclouds.org) as they have a ROS agnostic implementation.
Originally posted by KoenBuys with karma: 2314 on 2011-06-16
Comment by lakshmen on 2011-06-21:
I actually have written a code in C++ for the depth data and the point cloud data.I would like to publish the data, how should i do that?
Comment by lakshmen on 2011-06-17:
publishing and subscribing to the same topic u mean?
Comment by KoenBuys on 2011-06-17:
this requires subscribing to the topic of the openni camera and publishing to a new topic
Comment by lakshmen on 2011-06-16:
basically what i am trying to do is that i have written a code for the point cloud in C++ and want to implement it using ROS and plot it out in RVIZ... Any suggestions how i can go about doing it?
thanks.... will read thru it... if i have qns, i will ask you....
Comment by KoenBuys on 2011-06-16:
Have a look here: http://www.pointclouds.org/documentation/tutorials/openni_grabber.php#openni-grabber
i need to include both the publisher and subscriber code right?
i just want to have point cloud information.which method is better?
