hey all, i'm following the ROS tutorial 3 in which it teaches how to create a new package which has dependencies. when i enter the following: $ roscreate-pkg beginner_tutorials roscpp rospy std_msgs terminal shoots back: ERROR: dependency [roscpp] cannot be found
note : i've updated the ROS_PACKAGE_PATH variable. i have verified manually and (with rospack find also) that roscpp actually exists in my filesystem. its just that roscreate cant seem to find it.
any help would be greatly appreciated.
Originally posted by surfexceltide on ROS Answers with karma: 1 on 2011-06-13
Comment by kwc on 2011-06-13:
can you describe your install setup better? i.e. what is your ROS_ROOT, what is your ROS_PACKAGE_PATH, and where is roscpp? can you also verify that you can run "rospack find roscpp", then run the roscreate-pkg command and still get a failure.
Comment by mmwise on 2011-06-13:
in the terminal you're trying to roscreate-pkg, can you roscd roscpp. If not your package path is not set in that terminal
I suppose your ROS_PACKAGE_PATH is not set accordingly.
  1. Close your terminal and open again which will reload your ~/.ros to default one.
  2. Run the following again $ cd ~/ $ mkdir ros_tutorials $ export ROS_PACKAGE_PATH=~/ros_tutorials:$ROS_PACKAGE_PATH
  3. To verify whether your PATH set correctly, try 'roscd roscpp'. If it changes to the roscpp folder then path file is set correctly.
  4. Now try creating package with dependencies you wish.
Hope this would help you. Note: I am a newbie in ROS, please let me know if there is something wrong.
Originally posted by jintgeorge with karma: 16 on 2011-06-20
Comment by surfexceltide on 2011-06-22:
thanks! that was precisely the problem. now I directly edit my .bashrc file instead of updating my ROS_PACKAGE_PATH everytime i open a mew terminal.
If you installed diamondback via deb packages, to setup your environment use:
. /opt/ros/diamondback/setup.bash
Originally posted by Asomerville with karma: 2743 on 2011-06-14
Post score: 4
