Hi all, I recently updated my diamondback version to the latest version and I realised that my packages that I had written previously that used OpenCV's VideoCapture (webcam) fail to work. That is the code:
cv::VideoCapture capture;
capture.open(0);
always returns FALSE. When I compile the latest OpenCV 2.2 library outside the ROS framework and run it, my web cam is always initialised properly so I know its not a problem with OpenCV. My webcam works fine with Cheese as well so it's not at fault too. I am running Ubuntu 10.04 LTS with a full clean install of ROS Diamondback with the required vision-opencv stacks.
Has anyone else had the same experience? Or does anyone have any advice for me to take?
Thanks.
Originally posted by dkst on ROS Answers with karma: 21 on 2011-06-05
Comment by Yongqiang Gao on 2011-06-11:
Hi, dkst, have u solved this problem yet? I go through this problem, and have no idea about it. I reinstall my ROS, but it also doesn't work.
Comment by Julius on 2011-06-07:
Do you have an isolated test case that runs properly when linked against your manually compiled OpenCV libraries works, and does not work if linked against the pre-built OpenCV libraries in Diamondback? That would be pretty strange. Did you check out OpenCV 2.2 from branches/2.2 in revision 5206?
3 Answers 3
Hi all, the ROS opencv packge (opencv2) does not build the video interface options - we took this decision early because of the fragility of the OpenCV video capture and I/O code.
In use this tends not to be a problem because we usually source images via ROS, and use cv_bridge to import images (or sequences of images for video) into OpenCV.
Originally posted by James Bowman with karma: 136 on 2011-06-20
Comment by Brian Gerkey on 2011-06-20:
See also: https://code.ros.org/trac/ros-pkg/ticket/4980
That problem falls to me unluckily, after i arrange my older openCV libraries for trying to solve the problem that it can't open local video file.
I think it disorder the connections between vision_opencv. I haven't any constructively suggestion, except to re-install diamondback.
Anyone has some better advice?
Originally posted by Yongqiang Gao with karma: 133 on 2011-06-08
Comment by Leyonce on 2014-03-30:
I would have surely used this Idea if the others didn't work.Thanks
I was having the same problem trying to use create_webcam. It looks like there is just something wrong with whatever version of opencv gets installed through the ros repositories. My quick and dirty solution was to compile/install opencv from source, and then copy all of the libraries into the ros opencv/lib directory:
$ roscd opencv2/opencv
$ sudo mv lib/ lib.orig/
$ mkdir lib
$ cd lib
$ sudo cp libopencv* ./
Hopefully ros will get this sorted out soon, but this fix is working for me at the moment.
Comment by Yongqiang Gao on 2011-06-12:
I have just solved with this problem. For ROS originally doesn't support ffmpeg, we should turn on those flags at Makefile in "Opencv2" in "vision_opencv" , and then rebuild it. By the way, if ros in /opt/, it doesn't rebuild very well, so I copy "vision_opencv" into my "~/". Hope for helping u.
Cool pal.That's so cool.
