I am using pcl and pcl_ros from http://svn.pointclouds.org/ros/tags/unstable/perception_pcl/. I am publishing the pointcloud version .PCD v.7 using pcd_to_pointcloud tool and then trying to display it in diamondback version of rviz.
The latter however crashes rviz with the following message: """ rviz: /tmp/buildd/ros-diamondback-visualization-common-1.4.0/debian/ros-diamondback-visualization-common/opt/ros/diamondback/stacks/visualization_common/ogre/build/ogre_src_v1-7-1/OgreMain/include/OgreAxisAlignedBox.h:252: void Ogre::AxisAlignedBox::setExtents(const Ogre::Vector3&, const Ogre::Vector3&): Assertion `(min.x <= max.x && min.y <= max.y && min.z <= max.z) && "The minimum corner of the box must be less than or equal to maximum corner"' failed. (0) : fatal error C9999: *** exception during compilation *** """
I suspect it to be caused by NaNs in my pointcloud but then again this was not the problem for diamondback version of pcl_ros. Can anyone confirm if my guess is right and what would would the action to rectify the problem be?
D.
Originally posted by dejanpan on ROS Answers with karma: 1420 on 2011-05-30
Comment by kwc on 2011-06-17:
Closing as Eric Perko's comment is essentially the right answer.
Comment by Eric Perko on 2011-05-30:
Could you try it on rviz trunk? If it still doesn't work there, I suggest opening a ticket and then putting a link to it here as the answer. If a valid PointCloud (according to the PointCloud2 message type) causes rviz to crash, it's definitely a bug :)
Comment by dejanpan on 2011-05-30:
Hi Eric, the bt is here: http://pastie.org/1995774. And this is the pcd I am trying to visualize: http://ias.cs.tum.edu/~pangerci/alpen_milch_0195.pcd. It seems like the deb version of rviz is built w/o debug symbols as I am not able to get any listing of the code or such.
Could you run rviz in gdb and get a backtrace?
Comment by Ivan Dryanovski on 2011-05-30:
This might be the same issue?: http://answers.ros.org/question/928/rviz-window-closes-itself Spoiler alert, no solutions there either.
Could you try it on rviz trunk? If it still doesn't work there, I suggest opening a ticket and then putting a link to it here as the answer. If a valid PointCloud (according to the PointCloud2 message type) causes rviz to crash, it's definitely a bug :) - Eric Perko (May 30)
Originally posted by Wim with karma: 2915 on 2011-08-02
