Hi, I have wrote the following package totally the same as tutorials:robot_setup_tf,laser_scan_publisher,odometry_publisher. And I also wrote the following base controller package but when I run by roslaunch, it seems not call the callback. the base controller code:
#include <ros/ros.h>
#include <geometry_msgs/Twist.h>
#include <iostream>
using namespace std;
void cmdVelReceived(const geometry_msgs::Twist::ConstPtr& cmd_vel);
int main(int argc,char **argv)
cout << "123" << endl;
ros::init(argc, argv, "robot_setup_base");
ros::Subscriber cmd_vel_sub;
ros::NodeHandle node_;
cmd_vel_sub = node_.subscribe<geometry_msgs::Twist>("robot_0/cmd_vel", 1, boost::bind(cmdVelReceived,_1));
ros::spin();
return 0;
cout << "x=" << cmd_vel->linear.x << endl;
cout << "y=" << cmd_vel->linear.y << endl;
cout << "theta=" << cmd_vel->angular.z << endl;
And my launch file is
<launch>
<master auto="start"/>
<param name="/use_sim_time" value="true"/>
<node pkg="robot_setup_laser" type="laser" name="sensor_node_name" output="screen">
<param name="sensor_param" value="param_value" />
</node>
<node pkg="robot_setup_odometry" type="odometry" name="odom_node" output="screen">
<param name="odom_param" value="param_value" />
</node>
<node pkg="robot_setup_tf" type="tf_broadcaster" name="transform_configuration_name" output="screen">
<param name="transform_configuration_param" value="param_value" />
</node>
<node pkg="robot_setup_base" type="base" name="base" output="screen">
</node>
<!--- Run AMCL -->
<include file="$(find amcl)/examples/amcl_diff.launch" />
<node pkg="map_server" type="map_server" name="map_server" args="$(find navigation_stage)/stage_config/maps/willow-full.pgm 0.1" respawn="false" >
<param name="frame_id" value="/map" />
</node>
<node pkg="stage" type="stageros" name="stageros" args="$(optenv ROS_STAGE_GRAPHICS -g) $(find navigation_stage)/stage_config/worlds/willow-pr2-multi.world" respawn="false">
<param name="base_watchdog_timeout" value="0.2"/>
</node>
<!-- Throttle the voxel grid that is being published for rviz -->
<node ns="move_base_node/local_costmap" name="voxel_grid_throttle" pkg="topic_tools" type="throttle" args="messages voxel_grid 3.0 voxel_grid_throttled" />
<group ns="robot_0">
<param name="tf_prefix" value="robot_0" />
<node pkg="move_base" type="move_base" respawn="false" name="move_base_node" output="screen">
<remap from="map" to="/map" />
<param name="controller_frequency" value="10.0" />
<rosparam file="$(find navigation_stage)/move_base_config/costmap_common_params.yaml" command="load" ns="global_costmap" />
<rosparam file="$(find navigation_stage)/move_base_config/costmap_common_params.yaml" command="load" ns="local_costmap" />
<rosparam file="$(find navigation_stage)/move_base_config/local_costmap_params.yaml" command="load" />
<rosparam file="$(find navigation_stage)/move_base_config/global_costmap_params.yaml" command="load" />
<rosparam file="$(find navigation_stage)/move_base_config/base_local_planner_params.yaml" command="load" />
</node>
<node pkg="fake_localization" type="fake_localization" name="fake_localization" respawn="false">
</node>
</group>
<node name="rviz" pkg="rviz" type="rviz" args="-d $(find navigation_stage)/multi_robot.vcg" />
</launch>
And the output:
sam@sam-M51Kr:~/code/ros/ira_navigation/nav_core/launch$ roslaunch robot_conf.launch
... logging to /home/sam/.ros/log/e84ff146-891a-11e0-93d5-0015afe5d6b9/roslaunch-sam-M51 Kr-4359.log
Press Ctrl-C to interrupt
WARNING: ignoring defunct <master /> tag
started roslaunch server http://sam-M51Kr:41097/
SUMMARY
PARAMETERS
* /use_sim_time
* /amcl/gui_publish_rate
* /robot_0/move_base_node/TrajectoryPlannerROS/min_in_place_rotational_vel
* /base/transform_configuration_param
* /robot_0/move_base_node/TrajectoryPlannerROS/y_vels
* /robot_0/move_base_node/local_costmap/unknown_threshold
* /amcl/recovery_alpha_slow
* /amcl/laser_z_short
* /robot_0/move_base_node/local_costmap/origin_y
* /robot_0/move_base_node/TrajectoryPlannerROS/min_vel_x
* /robot_0/move_base_node/TrajectoryPlannerROS/sim_time
* /robot_0/move_base_node/TrajectoryPlannerROS/heading_lookahead
* /robot_0/move_base_node/global_costmap/base_scan/data_type
* /robot_0/move_base_node/global_costmap/static_map
* /amcl/laser_z_rand
* /robot_0/move_base_node/global_costmap/mark_threshold
* /robot_0/move_base_node/local_costmap/mark_threshold
* /robot_0/move_base_node/local_costmap/height
* /robot_0/move_base_node/local_costmap/base_scan/marking
* /robot_0/move_base_node/global_costmap/base_scan/marking
* /robot_0/move_base_node/local_costmap/z_resolution
* /robot_0/move_base_node/TrajectoryPlannerROS/vx_samples
* /robot_0/move_base_node/global_costmap/raytrace_range
* /robot_0/move_base_node/local_costmap/origin_x
* /robot_0/move_base_node/local_costmap/origin_z
* /robot_0/move_base_node/TrajectoryPlannerROS/sim_granularity
* /robot_0/move_base_node/local_costmap/observation_sources
* /robot_0/move_base_node/local_costmap/lethal_cost_threshold
* /robot_0/move_base_node/global_costmap/footprint
* /transform_configuration_name/transform_configuration_param
* /amcl/laser_lambda_short
* /robot_0/move_base_node/local_costmap/base_scan/observation_persistence
* /robot_0/move_base_node/local_costmap/resolution
* /amcl/laser_max_beams
* /robot_0/move_base_node/TrajectoryPlannerROS/goal_distance_bias
* /amcl/laser_model_type
* /robot_0/move_base_node/global_costmap/base_scan/min_obstacle_height
* /robot_0/move_base_node/local_costmap/publish_frequency
* /amcl/odom_model_type
* /amcl/laser_sigma_hit
* /amcl/recovery_alpha_fast
* /robot_0/move_base_node/TrajectoryPlannerROS/escape_vel
* /robot_0/move_base_node/global_costmap/update_frequency
* /robot_0/move_base_node/local_costmap/inflation_radius
* /robot_0/move_base_node/global_costmap/footprint_padding
* /robot_0/move_base_node/local_costmap/footprint_padding
* /robot_0/move_base_node/TrajectoryPlannerROS/prune_plan
* /robot_0/move_base_node/global_costmap/inflation_radius
* /rosdistro
* /robot_0/move_base_node/global_costmap/global_frame
* /robot_0/move_base_node/TrajectoryPlannerROS/vtheta_samples
* /robot_0/move_base_node/local_costmap/robot_base_frame
* /robot_0/move_base_node/local_costmap/global_frame
* /map_server/frame_id
* /robot_0/move_base_node/local_costmap/static_map
* /amcl/odom_alpha4
* /robot_0/move_base_node/local_costmap/transform_tolerance
* /amcl/odom_alpha1
* /amcl/odom_alpha2
* /amcl/odom_alpha3
* /robot_0/move_base_node/global_costmap/cost_scaling_factor
* /robot_0/move_base_node/TrajectoryPlannerROS/dwa
* /robot_0/move_base_node/global_costmap/z_resolution
* /robot_0/move_base_node/global_costmap/observation_sources
* /amcl/odom_alpha5
* /stageros/base_watchdog_timeout
* /robot_0/move_base_node/local_costmap/base_scan/min_obstacle_height
* /robot_0/move_base_node/local_costmap/width
* /robot_0/move_base_node/TrajectoryPlannerROS/acc_lim_y
* /robot_0/move_base_node/TrajectoryPlannerROS/acc_lim_x
* /robot_0/move_base_node/global_costmap/rolling_window
* /sensor_node_name/sensor_param
* /amcl/max_particles
* /amcl/laser_z_max
* /robot_0/move_base_node/local_costmap/update_frequency
* /robot_0/move_base_node/local_costmap/publish_voxel_map
* /amcl/min_particles
* /robot_0/move_base_node/local_costmap/base_scan/data_type
* /robot_0/move_base_node/local_costmap/z_voxels
* /robot_0/move_base_node/global_costmap/origin_z
* /robot_0/move_base_node/TrajectoryPlannerROS/max_vel_x
* /robot_0/move_base_node/global_costmap/publish_frequency
* /robot_0/move_base_node/TrajectoryPlannerROS/xy_goal_tolerance
* /robot_0/move_base_node/global_costmap/z_voxels
* /robot_0/move_base_node/local_costmap/base_scan/max_obstacle_height
* /robot_0/move_base_node/controller_frequency
* /robot_0/move_base_node/local_costmap/base_scan/clearing
* /robot_0/move_base_node/TrajectoryPlannerROS/oscillation_reset_dist
* /robot_0/move_base_node/global_costmap/obstacle_range
* /amcl/transform_tolerance
* /robot_0/move_base_node/global_costmap/base_scan/clearing
* /amcl/kld_err
* /amcl/resample_interval
* /amcl/odom_frame_id
* /robot_0/move_base_node/global_costmap/unknown_threshold
* /robot_0/move_base_node/TrajectoryPlannerROS/yaw_goal_tolerance
* /robot_0/move_base_node/TrajectoryPlannerROS/max_rotational_vel
* /robot_0/move_base_node/TrajectoryPlannerROS/occdist_scale
* /robot_0/move_base_node/global_costmap/lethal_cost_threshold
* /amcl/laser_likelihood_max_dist
* /amcl/laser_z_hit
* /robot_0/move_base_node/local_costmap/rolling_window
* /amcl/update_min_d
* /robot_0/move_base_node/global_costmap/max_obstacle_height
* /robot_0/move_base_node/local_costmap/obstacle_range
* /robot_0/move_base_node/local_costmap/cost_scaling_factor
* /robot_0/move_base_node/global_costmap/robot_base_frame
* /robot_0/move_base_node/TrajectoryPlannerROS/holonomic_robot
* /robot_0/move_base_node/global_costmap/base_scan/expected_update_rate
* /robot_0/tf_prefix
* /robot_0/move_base_node/local_costmap/map_type
* /rosversion
* /robot_0/move_base_node/local_costmap/raytrace_range
* /robot_0/move_base_node/TrajectoryPlannerROS/path_distance_bias
* /odom_node/odom_param
* /amcl/kld_z
* /robot_0/move_base_node/local_costmap/base_scan/expected_update_rate
* /amcl/update_min_a
* /robot_0/move_base_node/global_costmap/map_type
* /robot_0/move_base_node/global_costmap/base_scan/max_obstacle_height
* /robot_0/move_base_node/global_costmap/transform_tolerance
* /robot_0/move_base_node/TrajectoryPlannerROS/acc_lim_th
* /robot_0/move_base_node/global_costmap/base_scan/observation_persistence
* /robot_0/move_base_node/local_costmap/max_obstacle_height
NODES
voxel_grid_throttle (topic_tools/throttle)
/robot_0/
move_base_node (move_base/move_base)
fake_localization (fake_localization/fake_localization)
sensor_node_name (robot_setup_laser/laser)
odom_node (robot_setup_odometry/odometry)
transform_configuration_name (robot_setup_tf/tf_broadcaster)
base (robot_setup_base/base)
amcl (amcl/amcl)
map_server (map_server/map_server)
stageros (stage/stageros)
rviz (rviz/rviz)
auto-starting new master
process[master]: started with pid [4373]
setting /run_id to e84ff146-891a-11e0-93d5-0015afe5d6b9
process[rosout-1]: started with pid [4386]
started core service [/rosout]
process[sensor_node_name-2]: started with pid [4389]
process[odom_node-3]: started with pid [4390]
process[transform_configuration_name-4]: started with pid [4391]
process[base-5]: started with pid [4392]
123
process[amcl-6]: started with pid [4393]
process[map_server-7]: started with pid [4394]
process[stageros-8]: started with pid [4403]
process[move_base_node/local_costmap/voxel_grid_throttle-9]: started with pid [4418]
process[robot_0/move_base_node-10]: started with pid [4454]
process[robot_0/fake_localization-11]: started with pid [4457]
process[rviz-12]: started with pid [4493]
[ INFO] [1306580950.572397882]: Requesting the map...
[ WARN] [1306580950.608350236]: Request for map failed; trying again...
[ INFO] [1306580952.582282085, 1.000000000]: Received a 584 X 526 map @ 0.100 m/pix
[ INFO] [1306580952.628130027, 1.000000000]: Initializing likelihood field model; this can take some time on large maps...
[ INFO] [1306580953.041931902, 1.500000000]: Done initializing likelihood field model.
[ WARN] [1306580953.516881476, 2.000000000]: Message from [/sensor_node_name] has a non-fully-qualified frame_id [laser_frame]. Resolved locally to [/laser_frame]. This is will likely not work in multi-robot systems. This message will only print once.
[ INFO] [1306580959.034326825, 7.500000000]: Subscribed to Topics: base_scan
[ INFO] [1306580959.131188791, 7.600000000]: Requesting the map...
[ INFO] [1306580959.174969713, 7.600000000]: Still waiting on map...
[ INFO] [1306580960.148279766, 8.600000000]: Still waiting on map...
[ INFO] [1306580961.164992342, 9.600000000]: Received a 584 X 526 map at 0.100000 m/pix
[ INFO] [1306580962.145220653, 10.600000000]: MAP SIZE: 584, 526
[ INFO] [1306580962.242705462, 10.700000000]: Subscribed to Topics: base_scan
[ INFO] [1306580962.737211056, 11.200000000]: Sim period is set to 0.10
[ WARN] [1306580963.423087563, 11.900000000]: The base_scan observation buffer has not been updated for 0.50 seconds, and it should be T updated every 0.40 seconds.
[ WARN] [1306581053.524506038, 102.000000000]: MessageFilter [target=/odom ]: Dropped 100.00% of messages so far. Please turn the [ros.amcl.message_notifier] rosconsole logger to DEBUG for more information.
I have test
rostopic pub /cmd_vel geometry_msgs/Twist -r 20 '[1,0,0]' '[0,0,0.5]'
And it actually output x=1 y=0 theta=0.5
I have three simple question:
The origin purpose is try to get the output from the navigation stack. How could I get the velocity from the navigation stack with cmd_vel?
Why the output from '[1,0,0]' '[0,0,0.5]' is [1,0,0.5] ?
What is this message means?
Waiting on transform from /base_footprint to /odom to become available before running costmap, tf error: Frame id /base_footprint does not exist!
By the way,I have update the launch file and output result.
Now my launch file can run the navigation simulation with fixed map, and I also can get the cmd_vel like:
x=0.1
y=0
theta=0.0336842
x=0.1
y=0
theta=0.0168421
x=0.1
y=0
theta=0
x=0.1
y=0
theta=0.0505263
x=0.1
y=0
theta=0.0673684
It's seems great~~^^
My question:
When I change /use_sim_time to false,why the robot just disappeared? Should I also can get cmd_vel from robot_0/cmd_vel? or I should use /cmd_vel?
How to use the real robot's laser data to replace the simulation laser data in Rviz?
How to dynamic build map when robot moving, not to use the static map?
Thank you~~
Originally posted by sam on ROS Answers with karma: 2570 on 2011-05-26
