Let say I have a fast sensor that I use to control an actuator. For instance an encoder and a DC motor. The controller loop has to be quite fast in order to ensure proper control. I read that ROS design philosophy is "divide and conquer", i.e. small processes collaborating toward a goal. So here are 2 solutions:
One process to read the encoder value and post the current position / speed on a topic. One process that reads voltage on a topic and pass it to the motor. One process to run the PID controller using both topics and one more to accept velocity / position commands.
One single process that will do all of it in a tight loop, publish joint's position / velocity, and read position / velocity commands.
Of course, which solution to choose might depend on the hardware. For instance, if both the encoder and the motor are connected to the same DAQ card it make sense to have a single process to handle all the hardware on that card and do the PID control as well. In that case, it might be a rather complex process, depending on the number of IOs on the card.
But otherwise, assuming that the encoder and the motor are on independent hardware, which solution would be recommended? And how fast can a ROS process run?
The problem get slightly more complex when several actuators are used at the same time, i.e. when doing inverse kinematics on a 12 DOF robotic arm. How would you suggest to design such a piece of hardware? 36 nodes (3 per DOF: encoder, motor and PID), and one more for the inverse kinematics? Or one big node only that would accept different types of commands (direct joint control, control the end effector, etc. and publish the joint positions).
Other related scenario: on a robot, we have the odometer (updated every 10ms) and a gyro (updated every 5ms). I want to combine them both to obtain a more precise estimation of the robot's position. Here again there are 2 solutions, one with 3 processes (gyro, odo, and odoGyroPosSystem) and one with only one process that combines everything.
In the second case, everything is neatly coupled in one process. Typically one thread to read from the gyro, one to read from the odometer, and the main thread to combine the information.
With the first solution, I am curious to know what would happen. The gyro node would publish a new data every 5 ms? or packets would be aggregated and a listener would get several packets at once (jamming)?
I will be grateful for all comments
Originally posted by brice rebsamen on ROS Answers with karma: 1001 on 2011-05-25
