Hi All,
I am using Ubuntu 10.10 and try to install ROS. I followed every step found on the website, but something is wrong at the last step. Any suggestions or hints would be appreciated.The output is as follows. (The Linux kernel is 2.6.37, and before I tried to install ROS, I had installed Matlab R2010b -- not sure if this is related, just FYI)
$ sudo apt-get install ros-diamondback-desktop-full
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies: ros-diamondback-desktop-full : Depends: ros-diamondback-ros-tutorials (= 0.2.4-s1299046906~maverick) but it is not going to be installed
Depends: ros-diamondback-geometry-tutorials (= 0.1.3-s1299047065~maverick) but it is not going to be installed
Depends: ros-diamondback-slam-gmapping (= 1.2.2-s1301689879~maverick) but it is not going to be installed
Depends: ros-diamondback-ros (= 1.4.6-s1298587606~maverick) but it is not going to be installed
Originally posted by DG on ROS Answers with karma: 31 on 2011-05-18
Comment by DG on 2011-05-18:
Just updated. Thanks for reminding, Asomerville. First time here.
Comment by Asomerville on 2011-05-18:
Could you update the title of your post to more specifically state your issue; something like "Dependency install failure: ros-diamondback-ros-tutorials"
Yes, I ran it.
Comment by Eric Perko on 2011-05-18:
Did you run 'sudo apt-get update' before 'sudo apt-get install...'?
I got similar errors when I accidentally added the wrong package source. E.g., I added the source for Maverick even though I was running Lucid.
Double check which version of Ubuntu you are running using
cat /etc/issue
and the package source you added using
 cat /etc/apt/sources.list.d/ros-latest.list
Originally posted by sebsch with karma: 790 on 2011-05-25
