When I'm using gmapping to be SLAM in rviz, with the robot running there will generate more than one maps in RVIZ?
Originally posted by gong on ROS Answers with karma: 164 on 2011-05-17
Comment by gong on 2011-05-17:
Additional, I published odometry using the relative distance computed from odometry which provided by driver. The odmetry was like that : x = (current_odometry - last_odometry)*cos(theta), y = (current_odometry - last_odometry)*sin(theta), the theta was absolute value provided by gyro.
Further more, I got an error message. Error: m_distanceThesholdCheck overridden!!! ... the odometry has a big jump here. this is probably a bug in the odometry/laser input. This error has been happened someday ago, I rewrite the odomety program to fix it. At that time, the formula was wrong.
I set the fixed frames to "/odom" and set the laser scan's "delay time" to 10 seconds. It seems that I do not get the "mostly consistent map", because when the robot is running I cannot see the map in rviz until the robot is stoped.
Comment by Eric Perko on 2011-05-17:
I guess I wasn't clear about the "mostly consistent map". This would be without SLAM running, just using your odometry source to place the buffered laser scans into a mostly consistent reference frame.
as you can see from the screenshot, the map is jumping from one place to another
How are you generating/publishing odometry (e.g. p2os or your own custom robot driver)? Is your odometry accurate? If you run the robot around with the fixed frame in rviz set to "/odom" and set the laser scan's "Decay time" to a large number, do you get a mostly consistent looking map?
Could you add the screenshot that you sent to the mailing list as well, since it helps to explain what you mean?
Can you display the odom trajetory? It looks to me as you won't get something even near to the "mostly consistent map", but some jump in odometry.
Maybe it starts from some internal coordinates != 0, but send 0,0 as the first message?
Originally posted by dornhege with karma: 31395 on 2011-05-18
Comment by gong on 2011-05-18:
You are right. I think the problem is that I do not have a really fixed frame in the world coordinate. Though the fixed frame I set to /odom but it's not fixed. With the robot moving the location of /odom is change. Am I right?
I have been fix the problem. There is a mistake in my program about the odom computing. Thanks Eric and dornhege. Thank you so much!!
Originally posted by gong with karma: 164 on 2011-05-24
