Hi all,
I'm having trouble running rviz. I first start roscore in a terminal window, then open another terminal and execute 'rosrun rviz rviz.' The loading screen shows up, but the actual program interface never appears. No errors are reported. And if I run 'top' in another terminal, it looks like rviz is actually running, but it's just not visible. \
I should probably mention that I used to have cturtle and diamondback installed and I recently removed cturtle. I'm also running ubuntu 11.04.
Any help would be appreciated!
~Robin
Originally posted by Robin on ROS Answers with karma: 87 on 2011-05-17
Comment by dornhege on 2011-06-01:
Well, ROS has just been updated for 11.04 http://www.ros.org/news/2011/06/ros-packages-now-available-for-ubuntu-natty.html :)
Comment by Robin on 2011-06-01:
I checked and didn't see anything. I ended up just going back to using Ubuntu 10.10 and everything is fine again.
Comment by dornhege on 2011-05-18:
There should be printouts in the terminal or logfile. Is there anything about GLX missing or similar?
Comment by Asomerville on 2011-05-17:
You can also add details by editing the original question btw.
Comment by Robin on 2011-05-17:
dornhege: Well, ROS has just been updated for 11.04 http://www.ros.org/news/2011/06/ros-packages-now-available-for-ubuntu-natty.html
Originally posted by Wim with karma: 2915 on 2011-08-02
