Hi all, For several days, I (a relative newbie) have been trying to get the nav stack working. My map always came up offset from the robot in rviz (origin at lower left corner of map).
I finally found that the move_base.launch file in the "Setup and Configuration of the Navigation Stack on a Robot" tutorial (para. 3.5) is using a deprecated version of map_server arguments (as noted in the map_server code). It uses the "map_server " form rather than the "map_server <map.yaml>" form. The deprecated version doesn't work properly and the associated ROS_WARN message that map_server apparently should be displaying didn't show up on my terminal.
I suggest that the launch file be updated. This was pretty hard to track down.
Alex
Originally posted by Alex Brown on ROS Answers with karma: 176 on 2011-05-03
Please file this as a ticket using the appropriate trac. There's a link on the navigation wiki page.
Originally posted by tfoote with karma: 58457 on 2011-06-06
