Is there any way I can limit the depth to which I record data in rgbdslam? What I mean by this is, I don't want to accumulate points that are far away from the camera.
My main goal is to use rgbdslam to scan objects, but it involves a lot of human post-processing to isolate the object and the file sizes are very big. It would be nice if there was a way I could reduce the human element and reduce the size of these point clouds altogether.
Is there any way this can be done while recording data online? Or is the only way to do this is to scan the pcd file after wards and remove points that are far away (have a high (x^2 + y^2 + z^2)^.5 value).
Originally posted by Shark on ROS Answers with karma: 241 on 2011-04-21
