Where can I buy multi-directional omni wheels?
I'm specifically looking at something which can support in excess of 100kg/wheel, so around 400kg in total. Also, a possible mission profile would include a 300 meter excursion outdoors on asphalt path, so they should be a little durable. The only ones I can find online are small ones for experimenting.
pic
Try andymark, their 10 inch mecanums (or smaller) may suit you well.
Have seen in-action omni wheel industrial fork lift trucks like these image search.
https://www.google.com/search?q=omni+wheels+folk+truck&safe=off&tbm=isch&tbo=u&source=univ&sa=X&ei=aiqhU8DwDdWhugTy_oCIBA&ved=0CCoQsAQ&biw=1654&bih=813 Apparently, they are production items, although may not as widely used as the 'normal' wheel version
