When I add a camera plugin in rviz it appears at the top left of the screen. It is stuck under the application bar and I cannot move it.
When I switch compiz off, I can move it and dock it to rviz and switching compiz back on is OK, so I can then still move it around.
Does anyone know the reason for this or how to fix it?
I am using Ubuntu Lucid with gnome and compiz. The graphics card is a nVidia GT240.
Originally posted by dornhege on ROS Answers with karma: 31395 on 2011-04-04
3 Answers 3
The issue will be fixed in the next rviz release by creating new windows at (30,30)
Originally posted by David Gossow with karma: 26 on 2011-05-04
I also have this issue occasionally. I worked around it by activating the hide buttons on the Ubuntu main panel, so I can hide the panel, grab the camera window and then unhide the panel again. But I´d also be interested in a real solution.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2011-04-05
either the tip from stefan, or -with focus on the camera window- use alt-space to popup the window menu and select "move"
