Has anybody had success using the graph_slam package described at http://www.ros.org/wiki/graph_slam I tried checking out the source and building it but the dependencies do not build.
Or do you have any suggestions how I can build a topological map out of a SLAM gridmap fairly efficiently on the fly?
Edit: I am using the cturtle-pr2all stack
Originally posted by Dimitar Simeonov on ROS Answers with karma: 535 on 2011-03-29
Comment by Dimitar Simeonov on 2011-03-30:
CTurtle, sorry about that
Comment by Eric Perko on 2011-03-29:
Could you include which release (CTurtle or Diamondback) you are trying to use?
I didn't see this question till now, unfortunately. If you still need this, you can check out the new version of the topological_navigation stack (see www.ros.org/wiki/topological_navigation for instructions). In particular, the topological_map_2d package defines the topological map type and the laser_slam_mapper package constructs a node that constructs it.
Originally posted by bhaskara with karma: 1479 on 2011-05-18
