Hi folks,
I want to show rgb values of a point cloud in rviz where I store some information inside the rgb channels. However, there is not any choice named "channel", as it is shown here.
I've tried to add various builtin display types, such as PointCloud2, PointCloud and even LaserScan but none of them contains a channel field.
I've tried to add plugins as it is mentioned in this question. But I couldn't add any plugin via the Plugins->Manage tab of the rviz. So, I cannot obtain something like this.
I've checked the rviz folder in case there might be a folder named plugins or anything related to the plugins but no success.
I tried rviz --help but no information there also.
Can someone please tell me how can we do such a simple thing:) ?
Thanks
Originally posted by Kadir Firat Uyanik on ROS Answers with karma: 288 on 2011-03-29
Post score: 4
Comment by Eric Perko on 2011-03-29:
If you want to treat an arbitrary channel in the PointCloud as an intensity value, there is a patch for that. See https://code.ros.org/trac/ros-pkg/ticket/4610 . If you checkout trunk of the visualization stack and rebuild rviz, you should have access to that functionality to try it out.
Comment by Kadir Firat Uyanik on 2011-03-29:
They are in the type of pcl::PointXYZRGB and I obtain the RBG values in 24bit packaged format.
What is the "type" of the points in the PointCloud2 you are publishing?
If the pointcloud is of type XYZRGB you should be able to select RGB8 under "Color Transformer".
Originally posted by JediHamster with karma: 995 on 2011-03-29
Comment by JediHamster on 2011-03-29:
I think it does stand for 8 bits per channel.
I had tried Color Transformer with RGB, rgb and so on, but not RGB8. Thanks..Btw, does "8" in RGB8 stands for 0-255 scale(= 8bit total) or 8 bit/channel? Because as I said before, pointcloud stores 24bit color value in the rgb field.
