Anyone getting this to work, following the directions at http://www.ros.org/wiki/openni_tracker?
I get the following:
Warning: USB events thread - failed to set priority. This might cause loss of data...
Find user generator failed: Can't create any node of the requested type!
This with the unstable branch of perception_pcl on OS X.
Other openni binaries work, like NiViewer.
I have the NI binaries from PrimeSense, but maybe they need to be in a specific location? Or marked in one of my paths?
Originally posted by Eponymous on ROS Answers with karma: 255 on 2011-03-26
That suggests to me that you have not installed the NITE binaries and registered the plugin with OpenNI correctly. How did you install OpenNI and NITE?
Originally posted by tfoote with karma: 58457 on 2011-04-12
Comment by Eponymous on 2011-04-12:
Got the binaries, since I can't install from source on OS X. Think I put in the code correctly. How should I have done it?
