Is it possible to model a URDF file, using blender or other similar software?
Originally posted by GeniusGeeko on ROS Answers with karma: 299 on 2011-03-18
Hi GeniusGeeko,
you may export your model done in Blender into collada and then use collada_urdf converter to convert into URDF format: https://kforge.ros.org/robotmodel/robot_model/file/d33189ce4a62/collada_urdf/src/collada_urdf.cpp D.
Originally posted by dejanpan with karma: 1420 on 2011-03-18
Comment by GeniusGeeko on 2011-03-18:
Alright, awesome! Thanks for this. I'm testing it now.
I don't believe that any 3d modeling software can directly output a URDF file.
I believe that the best way to go about creating a URDF file from a CAD package is to export a set of your critical dimensions as a CSV file or the like. Most, if not all, CAD packages allow you to define a set of critical dimensions to export. You can then parse these critical dimensions into a set of XACRO variables that you can use in the rest of your URDF files.
Once you have set this up once, you could then just re-export the CSV and re-run your parser each time that the 3d model changes.
You can also export your STL files to allow for "prettier" robot models.
Originally posted by mjcarroll with karma: 6414 on 2011-03-18
Alright thanks, I'll check it out. If I don't like it, I'll stick to making them from scratch.
