This is quite a basic question. I'm practising robot programming with VRep. I have 2 K3 robots in the scene. One robot follows a predefined path. I want the second robot to move "in parallel" with the first one so they keep same orientation and same distance at all time. When there is a turn, I want the follower to slow/accelerate a little to keep the parallel.
In my implementation, I use wireless communication. The first robot will periodically "tell" the second about its speed, orientation. The second will use these parameters to calculate two speed to its two wheel. But when I run it, it doesn't work. The orientation of the follower is wrong. The distance is not maintained. I was totally confused.
I think this is quite a rudimentary task. There must be some practise to follow. Can somebody help to provide some ideas, references? That will be highly appreciated!
