Hi All,
If anyone has any links or references about connecting 2 or more Kinects to the same computer and specifically obtaining & integrating data from them, could you please reply here? So I am able to launch separate files for each kinect and am able to launch data separately. Here's the output of my rxgraph image description
The problem is my process listens to a topic and it cannot distinguish between same topics from different nodes, how can I make them publish topics with unique names? or how can I listen to topics from a specific node?
Best,
CV
Originally posted by blueskin on ROS Answers with karma: 284 on 2011-03-09
Comment by blueskin on 2011-03-09:
@tfoote: I've edited the question, thank you.
Comment by tfoote on 2011-03-09:
Could you specify what you mean by multiple kinects? Do you want data on connecting multple kinects on one computer or are you talking data fusion?
The new drivers used by openni_kinect support multiple cameras on one computer.
For fusing data I suggest looking PCL
Originally posted by tfoote with karma: 58457 on 2011-03-09
thanks tfoote, I'll try it and let you know.
To make each instance publish on a different topic use topic remapping Also there is roslaunch syntax for remapping
awesome, this is what I was looking for. Anyways, even after remapping am not able to visualize both kinects using RVIZ.
