Is it possible to change the Kinect point cloud resolution, via openni_camera or openni_node, such that fewer points are returned ?
Originally posted by JediHamster on ROS Answers with karma: 995 on 2011-03-06
Check out the Changing driver settings section of the openni_camera wiki. The parameter you'd want to tweak is depth_mode. The Kinect openni_node driver supports VGA(640x480), QVGA(320x240), and QQVGA(160x120) resolutions of the point cloud, all at 30Hz.
Originally posted by Ivan Dryanovski with karma: 4954 on 2011-03-07
Post score: 4
Comment by tom on 2011-03-10:
Please mark the question as answered.
Comment by JediHamster on 2011-03-07:
Ok, using a value of 8 for both depth and image I can get the QQVGA resolution.
Comment by Ivan Dryanovski on 2011-03-07:
Are you sure? I think I used the 160x120 before. Make sure you select the 30Hz though, otherwise it won't work
It looks as if the QQVGA resolutions aren't available, but QVGA does work and gives a much better update rate.
