Hi, I use ros-cturtle-pr2all, I found when I add an object and select it and delete that model and select gazebo again, the gazebo will disappeared. I can repeat this situation.
step: 1.open gazebo: roslaunch gazebo_worlds empty_world.launch
2.add an object: sam@sam-laptop:~/code/ros/cad/stl$ rosrun gazebo spawn_model -file top.urdf -urdf -model top -z 0.5 loading model xml from file attempting to spawn robot in simulation waiting for service spawn_urdf_model spawn status: SpawnModel: successfully spawned model spawning success True sam@sam-laptop:~/code/ros/cad/stl$
3.select that object (ctrl+left mouse click) It will show circles around that object
4.delete that model sam@sam-laptop:~/code/ros/cad/stl$ rosservice call gazebo/delete_model '{model_name: top}' success: True status_message: DeleteModel: successfully deleted model sam@sam-laptop:~/code/ros/cad/stl$
5.select gazebo flat world again(ctrl+left mouse click) Gazebo will disappeared.
Originally posted by sam on ROS Answers with karma: 2570 on 2011-02-25
Comment by sam on 2011-02-26:
Yes,I have to restart gazebo to continue my work. Sorry for using misunderstanding word.
Comment by Tully on 2011-02-26:
by "disappearing" do you mean gazebo crashes?
yep, you've found a bug. I needed to do
gazebo::World::Instance()->SetSelectedEntity(NULL);
before calling DeleteEntity(...).
Ticketed with patch for unstable.
Originally posted by hsu with karma: 5780 on 2011-02-28
