I want to translate my previous code by opencv2.2 into ROS, and I have found many differences between opencv and ROS in image type and some other types. So I wander if some one have already developed a long time on it, please give me some advices?
Thanks a lot!
Originally posted by Yongqiang Gao on ROS Answers with karma: 133 on 2011-02-22
ROS default install uses OpenCV 2.0 You can upgrade to 2.2 if you replace the ROS opencv2 package with the one available her: http://www.ros.org/wiki/vision_opencv just do svn co https://code.ros.org/svn/ros-pkg/stacks/vision_opencv/trunk and make it.
Originally posted by Yogi with karma: 411 on 2011-02-23
Comment by fergs on 2011-02-23:
Just a note -- cturtle used OpenCV 2.0, diamondback/unstable are using 2.2
I suggest you take a look at the documentation for the vision_opencv stack. Diamondback will include OpenCV 2.2, so that shouldn't be a problem for you.
As far as the differences between OpenCV and ROS image types, the cv_bridge addresses these concerns. Make sure to read the tutorials linked to from the cv_bridge package documentation to learn how to convert ROS images to OpenCV images and vice versa. Because Cturtle and Diamondback have different cv_bridge APIs, you should make sure you have the proper version selected when viewing the tutorials.
Originally posted by Eric Perko with karma: 8406 on 2011-02-22
