From my ros-users post:
So I have been following the really nice (R2D2) tutorials on URDF, thanks a lot for those! I've managed to get our robot model into RVIZ and follow base_link, but the transforms on the URDF besides base_link all seem to time lag, causing some jittery looking motion:
http://www.youtube.com/watch?v=GiQUc8FG6m8
We originally noticed that the static TFs defaulted publishing from joint_state_publisher at 10Hz, so we set it to 100Hz. This upped the maximum rate published to that of our base_link (~50Hz from our odom source), but this is what you see in the video.
The model does not jitter in RVIZ if the target and fixed frame are set to base_link, but does jitter when fixed frame is odom. We are playing data from a recorded bag file using --clock and have set use_sim_time to true. I've attached a copy of the xacro file I use to generate our urdf in case I've made a mistake in there.
Thanks,
- Chad
It would be nice to have the links update and move synchronously for the robot model. Is this something that should have a ticket made? Are there other solutions than editing the timestamps in the bagfile?
Originally posted by Chad Rockey on ROS Answers with karma: 4541 on 2011-02-20
I think that the most proper fix is to file a ticket against rviz to update the robot model atomically.
The development version of tf2 deals with static transforms natively, however that won't fix this problem completely if some of the joints are not static.
Originally posted by tfoote with karma: 58457 on 2011-03-28
Comment by littleghost on 2019-02-01:
The link is broken, could you post a new link?
