For many applications, communication between robots is necessary. What is currently the recommended best practice for achieving that?
Originally posted by Stefan Kohlbrecher on ROS Answers with karma: 24361 on 2011-02-19
Post score: 7
There is currently no best practice for multiple robots, but there are some commonly used tools for different configurations:
  • foreign_relay: shuttles data between distinct ROS systems.
  • zenmaster_sd: uses bonjour to sync data between multiple masters
  • wifi_comm: combines foreign_relay with discovery
Originally posted by kwc with karma: 12244 on 2011-02-20
Post score: 7
Comment by pacifica on 2012-12-04:
Hi kwc! Can you tell me if these 3 configurations are running in ros fuerte??
Assuming all those robots are running ROS, doing like this should be the right solution, I suppose.
Originally posted by tom with karma: 1079 on 2011-02-19
Comment by Stefan Kohlbrecher on 2011-02-20:
Hi tom, this is indeed a valid answer, it is however not advisable to have multiple robots use a single master, at least in the real world where wireless connections and other factors make that this a very brittle solution.
Comment by Patrick Bouffard on 2011-02-20:
That page is a good starting point but seems geared more towards a 2-machine setup. If one of the machines is an off-board laptop then that's still only one robot. This seems to be an area of active development and one of the areas of focus in a project underway at WG (search for BuildingManager...)
